Thread: Clunking Noise
    Default Clunking Noise
    Hey everybody lookin for some advice. When I am coasting down the road and re apply pressure to the accelerator I Hear a clunk, almost as if there is play some where. I was thinking this may be my U joints but im not sure. Any ideas?
    thanks
    Easy way to tell if it's your U joints, go under your truck, grab your drive shaft and go to town, if there is any give. replace them. If no give, take a big screw driver and wedge it in there and see if there is any give, front and rear U-joints. They're only $20, better be safe then sorry, its worth the $80, instead of the $200 tow to the shop because you bust a U-joint in the middle of the street.
    www.youtube.com/ippielb
    stephan's Avatar
    Far West, Oregon USA,
    Ditto to what Ippielb said, & while you're under there be sure and check the rear trans mount. They are known for coming loose and clunking every time you get on, or off the gas.
    3" susp. lift kit "shadetree"
    I did check for with just my hands and there was no give , but I will try with the scewdriver. Will also check the trans mount. Thanks for the help
    murdog94's Avatar
    Year make, and model will help a bit as well since some years the backlash on the rear differential gears was higher than others so it would allow for a clunk like you are describing.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Its a 2004 Z71 Chevy Silverado 72,000 miles 5.3
  1. Clunking Noise =(
    By blueZ71 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-15-2012, 03:58 PM
  2. Clunking noise
    By Minnesota Mudder in forum Lifted & Offroad Suspension
    Last: 01-13-2010, 11:35 AM
  3. Clunking Noise in Rear End
    By dizzy17 in forum General Chevy & GM Tech Questions
    Last: 12-10-2009, 09:43 PM
  4. Clunking noise
    By helomech09 in forum General Chevy & GM Tech Questions
    Last: 07-31-2009, 07:46 AM
  5. Clunking noise issue
    By gasixgunner in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-13-2009, 07:35 AM
