    Question 2003 Chevy Silverado Regular Cab LS
    I am looking to put a 2" lift on my truck for the front... I found a 2" spacer to put on top of the coils and then I also found a coil that is 2" bigger and supposadly lifts the truck that way (no spacer) and is cheaper. What route would you all take? What route have most taken? Any advice?
    i know the spacer is popular. havent heard much of the larger coil but sounds like it should work well.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    I kinda like the coil idea. Its probably a stronger coil for one and you could also upgrade shocks while your at it if you want. Also rancho makes a 4'' lift using coils and shocks
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
    stephan's Avatar
    Far West, Oregon USA,
    Hi Elg, welcome to the GM Truck Club.
    Most people go with the spacer but I agree with the others that the new coil is the way to go. It will give you a better ride quality because a spacer crams the stock spring into a smaller space and increases the spring rate which makes it ride rougher.
    edit*** Hey ELG, what company carries those springs? I would like to see if they have something for my old beater. Thanks..
    3" susp. lift kit "shadetree"
    Master Mechanic clgoch187's Avatar
    Aug 2010
    Gettysburg, Pennsylvania, United States
    and this is for a 2003? 2wd or 4wd? all i ever find is the torsion keys and the dropped crossmember kits
    03 Silverado 1500
    285/75/16 BFG's
    2 Blaupunkt 10" vW1000 subs in Subthump box
    ProComp Level Lift & 3" rear blocks
    http://cgi.ebay.com/ebaymotors/SILVE...item53e2f54205
    I found them here and wondered if they would work...They even have 3" which Im looking into
    This is for a 2003 2wd
    stephan's Avatar
    Thanks Elg, I'll check & see if they have anything for mine.
    Last: 07-26-2010, 03:50 PM
  2. Replies: 0
    Last: 05-28-2010, 12:50 PM
  3. 2003 Chevrolet C2500 Regular cab Utility bed 2wd truck
    Last: 03-27-2010, 01:30 PM
  4. Replies: 0
    Last: 02-19-2010, 05:30 PM
  5. 2000 chevy Silverado 2500 Regular Cab parts for Repair
    Last: 08-04-2009, 04:50 PM
