Results 1 to 10 of 34
Thread: Sway Bars
    Master Mechanic HawaiiKid's Avatar
    Feb 2010
    Honolulu, HI
    Post Sway Bars
    So the Hellwig swaybars I ordered last week came in! Well, the front one did at least. So, being how I am (always excited for my next project) I immediately ripped into the box, pulled the parts out and rushed to get under the truck to install it! No problem yet, right? So in order to install the front sway bar, I needed to pull the stock one (that I didn't even know I had) off. First bolt pain in the -ss, but I got it off ok. Second bolt-stripped. Third bolt-part way off, then stripped. Fourth bolt-stripped. WD-40'd em, didnt do anything but drip in my eye. So...now I'm stuck there, because I don't have a good garage to work in (aka, no real lights, and lots of Hawaiian B-52 cockroaches ) and its real dark out. Any advice on how to get these stripped bolts out? I'm thinking I might just have to take it to a shop and have them drill em out or something. Anyways, here are a few starting pics. BTW, this sway bar is SOLID, super heavy and clearly really well made.
    EDIT: Anyone think something like this would work? Threads arent stripped (I dont think), the heads on the bolts are just really rounded off).
    http://www.sears.com/shc/s/p_10153_1...id=00952166000
    2003 Silverado, SOLD 1/11/11 for my... 2001 Ford Mustang Bullit, #1787
    :/ That sound like a horrible experience. Depending on how stripped the bolts are, you may have a hell of a time getting them off all together. If there are absolutely no angles on the bolt heads to work with, you may have to drill out the bolt. Just be careful not to mess up any of the threading or you'll really be in trouble. Or you can pick up a screw/bolt extractor for a minimal price and try that out.
    Go ahead and get the stripped head bolt removers from Sears. I have a set. They're worth their weight in gold if they save you from having a shop drill them all out.
    Are the nuts captive or welded to the frame somewhere? If so you want to avoid drilling them out at all costs. I'm used to replacing them on cars and you can usually get at the the nut and bolt. So vice grips will sometimes save your butt.
    If that kit comes with poly bushings make sure you lube them really well and that the bar rotates freely in them *before* you start hooking up the end links. Once you torque down the bolts that hold the retainers on the bushing. If the bar won't rotate freely. Then the bushings are grabbing it too tight. That is bad. You'll need to put a washer on the back side of each bracket then bolt it down. That will stop the bushing from being compressed so much. If you don't get it right then the bar will not work right.
    If you have adjustable end links you want no preload. If not just connect the end links and have at it.
    2006 Chevy Silverado, 5.3L, Z71, Extended Cab. Tow Mule.
    2002 Chevy Corvette Z06, 5.7L, Slightly Modded. Tow Payload.
    2005 Craftsman Riding Mower, 17hp, light mods.
    I'd say go with the sears bolt removers as well. I've also had pretty good success with easy out kits. Did your new kit come with replacement bolts by the way?
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
    Yeah... good points. I would try anything before having to drill out a bolt. Give 'em a shot.
    Feb 2010
    Honolulu, HI
    Quote Originally Posted by vms4evr View Post
    Ok, I will def make sure the bar is lubed up well before installing it...it came with a little bottle of lube so I'll make sure to use it. And I'll also make sure to not over tighten the fittings on the bushings, the Hellwig instructions were also very clear about not over tightening things!
    Quote Originally Posted by ntbush83 View Post
    New kit did NOT come with replacement hardware, but I already bought 4 new bolts from a local hardware store to replace them. I'm def going to go pick up that kit this afternoon.
    Quote Originally Posted by Vincennes02261897 View Post
    I really dont want to drill it out, esp cause the bottom bolt would be almost impossible to get a straight angle on.
    Thanks for the advice, going to pick up this kit after work today!
    Make sure the bolts you purchased are grade 5 or 8 as cheap ones may break.
    Definitely use the lube on all the bushings. I changed the bushings on the sway bar on my Jimmy. I ordered black ones from NAPA and they ended up being black urethane instead of rubber and they squeaked all the time unless it was raining!
    2006 Impala LT 3.5L
  1. Aftermarket sway bars?
    By HawaiiKid in forum Lifted & Offroad Suspension
    Last Post: 09-28-2010, 01:19 AM
  2. 1999 Tahoe - Sway Bars
    By Sparg93 in forum Chevy Truck Accessories
    Last Post: 11-30-2009, 09:02 PM
  3. nerf bars, step bars
    By MXZ1983 in forum General Classifieds
    Last Post: 09-13-2009, 12:51 PM
  4. Hellwig F&R Sway Bars
    By Never Enough in forum Lifted & Offroad Suspension
    Last Post: 10-22-2008, 10:44 PM
  5. Rear Sway Bars
    By BESherman in forum Lifted & Offroad Suspension
    Last Post: 10-27-2007, 06:26 PM
