Results 1 to 2 of 2
Thread: Fuel Pump
    Default Fuel Pump
    i have an 86 chevy w/305 and i want to put a electric fuel pump on it. what psi should the fuel pump run? something for an everyday driver.
    stephan's Avatar
    Far West, Oregon USA,
    86? Truck or Car??
    This is carbuerated & NOT TBI right? A Rochester 2 or 4 barrel right? 6 psi is all you need. 7 psi is ok too but if you get a pump that puts out more than that you will need to put a pressure regulator on it too, or it will overcome the float pressure on the needle & seats & flood over the bowl level. Both the Holley offerings are too much pressure, but Carter used to make a 6 1/2 or 7 psi pump. Before you buy, be sure & read the spec sheet, or ask to see the description in the parts mans book as to what the real pressure is. Don't just go by what he tells you.
  1. Replies: 4
    Last Post: 09-19-2010, 06:16 PM
  2. Which fuel pump do I need?
    By Keats in forum Performance & Fuel
    Last Post: 05-12-2010, 12:35 AM
  3. Fuel Pump
    By sxracerb25 in forum Performance & Fuel
    Last Post: 05-08-2009, 10:18 AM
    Last Post: 09-26-2008, 05:10 PM
    Last Post: 09-05-2008, 02:55 PM
