Results 1 to 1 of 1
    Thumbs up NEW: European Car Formula Synthetic 5W-30 Motor Oil (AEL)
    AMSOIL European Car Formula 5W-30 Synthetic Motor Oil provides exceptional performance and protection for high-performance European vehicles made by Volkswagen, Audi, Mercedes-Benz, BMW, Porsche and more. Its low-viscosity formulation maximizes fuel efficiency without compromising engine protection, while meeting strict European performance requirements for gasoline and direct-injection diesel engines designed for low-viscosity oils. Formulated with low sulfated ash, phosphorus and sulfur (SAPS), AMSOIL European Car Formula 5W-30 Synthetic Motor Oil complies with modern emissions systems to provide optimum life and performance.
    AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL, The First in Synthetics®, to do the best job protecting your engine.
    Stay-in-Grade Performance
    Sophisticated European engines subject oil to severe operational conditions. Oils must demonstrate excellent high-temperature/high-shear (HT/HS) performance to maintain viscosity and provide adequate engine protection. AMSOIL European Car Formula 5W-30 Synthetic Motor Oil is engineered to stay in grade despite rigorous operation throughout the extended drain intervals European automakers recommend. Formulated with a select additive package and shear-stable synthetic base oils, it meets strict ACEA and VW HT/HS requirements to provide outstanding wear protection throughout the entire drain interval.
    Low-SAPS Formulation
    Excessive sulfated ash, phosphorus and sulfur (SAPS) in motor oil can harm modern exhaust treatment devices. Diesel particulate filters (DPFs), for example, require low-SAPS motor oil to resist filter plugging. AMSOIL European Car Formula 5W-30 Synthetic Motor Oil’s low-SAPS formulation promotes optimum emissions system performance and life, allowing reduced maintenance costs.
    Maximum Fuel Economy
    AMSOIL European Car Formula is engineered with a lighter 5W-30 viscosity and friction modifiers to reduce friction for increased energy through-put. It minimizes internal engine drag, providing an alternative for motorists currently using heavier-grade oils, but who desire maximum fuel efficiency.
    Enhanced Turbocharger Protection
    Turbocharged Direct Injection (TDI) engines commonly used in European vehicles require thermally stable oils that resist deposit formation and provide turbocharger cooling. Thermally stable oils help keep oil passages clean and promote fluid circulation so turbo bearings stay cool and lubricated.
    AMSOIL European Car Formula 5W-30 Synthetic Motor Oil provides protection and performance for TDI systems in all temperature extremes. Its low pour point protects turbochargers against oil starvation and ensures rapid oil pressure in sub-zero conditions, while its thermal stability withstands high-temperature/high-RPM breakdown to resist deposit formations that can starve TDI systems of lubrication.
    APPLICATIONS
    AMSOIL European Car Formula 5W-30 Synthetic Motor Oil is formulated to meet or exceed the most demanding European specifications. It is recommended for European gasoline or diesel vehicles requiring any of the following performance specifications:
    • VW 504.00/507.00
    • ACEA A3/B3, A3/B4
    • Mercedes-Benz 229.51
    • BMW LL-04
    • Porsche C30
    SERVICE LIFE
    Recommended for the extended drain intervals established by the vehicle manufacturer. Change oil filter at time of oil change.
    COMPATIBILITY
    AMSOIL European Car Formula Synthetic 5W-30 Motor Oil is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil’s life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed.
    Aftermarket oil additives are not recommended for use with AMSOIL motor oils.
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Last: 07-15-2010, 09:00 AM
  2. AMSOIL Signature Series 0W-30 100% Synthetic Motor Oil (SSO)
    By 1st Synthetics in forum 1st Synthetics
    Last: 06-02-2009, 10:35 PM
  3. Synthetic or regular motor oil
    By spyder in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-23-2009, 10:45 AM
  4. synthetic or traditonal motor oil?
    By NixZ71 in forum General Chevy & GM Tech Questions
    Last: 03-14-2008, 11:51 AM
  5. Replies: 0
    Last: 01-31-2008, 10:21 PM
