GM Truck Club
Results 1 to 3 of 3
    Default Intake gasket leaks anti-freeze
    Hi, I have a 1999 suburban with a 5.7, 87,000 miles. It is leaking fluid from the back of the engine,drivers side. It looks like it's coming from where the intake manifold and head/block meet. Do I need a new gasket? If so ,any tips on how to or what gaskets to use? Thank you.
    Legend
    stephan's Avatar
    Sep 2010
    Far West, Oregon USA,
    The proper way to fix it would be to replace the gasket, but I would try tightening the bolts a little bit first. Go easy here, just check & see if they are as tight as the others.
    Another thing you could try, but is not recommended except as a last resort if you really hate engine work would be to try a can of Barrs Leak. Only use 1/2 of the small bottle/can. Get an even mixture of the pellets & the liquid. Give it a couple hours of running to circulate completely. If the leak persists add the rest of the can & give it a couple of days to seal. If it hasn't stopped, then you'll just have to replace the gasket...
    If it comes down to needing gaskets use GM.....
    1988 Chevy C-3500 2wd (no pic)
    350 c.i. 5.7 L Stock Block, 4 Bolt Mains
    L-31 Vortec Heads, Edelbrock Cam & Intake,
    Holley 650, Flowtech Headers, Magnaflow exh.
    Jet Trans 700R4, B&M Ratchet, 4:10 gears,
    3" susp. lift kit "shadetree"
    No rev limiter, No speed limiter lol
    That gen of Vortec 305s & 350s are notorious for loosing intake gaskets. I wouldn't wait another day to get it repaired. I replaced mine last spring. After seeing how it all works, it's obvious that a small leak could become a catastrophic failure without notice. Fill the lifter valley with coolant, you'll likely be replacing the engine.
Similar Threads
  1. 87 C10 Holley Throttle Body to Edelbrock gasket leaks
    By cyberpine in forum Chevy C/K Truck Forum
    Last: 02-04-2010, 04:32 PM
  2. Intake Gasket or something else
    By humnbass in forum General Chevy & GM Tech Questions
    Last: 12-11-2009, 12:15 AM
  3. Intake Gasket
    By mrcaddy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-08-2009, 01:30 PM
  4. loosing anti-freeze and dont know where
    By nvyseal11 in forum GM Powertrain
    Last: 11-02-2007, 01:00 AM
  5. Dead mouse smell in anti freeze.
    By craig in forum The Coffee Shop ~ Chit Chat
    Last: 11-17-2006, 10:04 AM
