    Aug 2009
    Gulfport, MS
    Default Heat is not working!!!
    My heat has started to fail me on my truck, It blows out cold air. After about 20 minuets of driving is will just all of a sudden start pushing out hot air. Not sure if it is electrical or just the knobs.
    I have a 2002 silverado with the dual climate control knobs that go up and down. Thanks
    stephan's Avatar
    Far West, Oregon USA,
    If your temp guage is showing that your thermostat is working properly, then it sounds like your blend doors is sticking & then just popping open & allowing the warm air to finally circulate. These systems are complicated so if you don't understand how it works, I would recommend taking it to someone who knows.
    3" susp. lift kit "shadetree"
    Had this same problem in my 01', I've been noticing the same issues with my buddies trucks. Just do a back flush on your heater core and see if that helps. I've hardly ever seen a temp door on those trucks fail. I did mine last winter and no problems since.
    Aug 2009
    Gulfport, MS
    Default How do I do a back flush?
    Quote Originally Posted by MNChevyguy View Post
    ---------- Post added at 08:30 AM ---------- Previous post was at 08:22 AM ----------
    Around how much would it cost to pay and have someone fix those doors, if that is the problem.
  1. Replies: 7
    Last Post: 12-20-2010, 01:20 PM
  2. Rear air and heat not working?
    By csmac2004 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 10-17-2010, 11:23 AM
  3. Replies: 5
    Last Post: 09-12-2009, 06:23 PM
  4. No heat up front, but heat in rear on '83 'burb
    By FUNFINDER in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-20-2009, 02:50 PM
  5. air/heat blower not working?
    By gabronco91 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-14-2008, 01:13 AM
