GM Truck Club
Page 2 of 3 FirstFirst 123 Last Post byLast Post by
Results 11 to 20 of 22
  1. #11
    cool guys...I think I am just going to run amsiol 75w-90 in the front and rear diffs.Shouldn't hurt anything...Should it?
    Here is what I'm thinking of using...
    https://www.amsoil.com/storefront/svg.aspx?zo=1695636
    What do you guys think?
    03 Chevy Silverado 1500 ext cab Z-71
    79 AMC Spirit GT
    77 Olds cutlass supreme
  2. #12
    Nothing wrong with that ./....
  3. #13
    cool,thats what I'll run then.
  4. #14
    Does the transfer case have a substitute? And does anyone know the capacity for the front?
    Thanks for the help.
  5. #15
    Quote Originally Posted by P51-Mustang View Post
    You just put tranny fluid in the t-case unless you have a button on your 4wd switch that says auto 4wd then it would take auto-trak II fluid.I think the front takes just under 2 quarts.
  6. #16
    Jr. Apprentice z71Hauler's Avatar
    May 2009
    Homestead, Fl.
    In the 2005 models you so not have to add any posi additives. The manual just says to use synthetic fluid. I have Mobil 1 in the diff with a MagHytec cover (4 quarts). Never had a problem.
    2005 Chevy Silverado Z71 5.3 ext. cab
  7. #17
    [QUOTE=vms4evr;306253]Thanks Hobey. Yeah I had to add the riding mower since it has mods too!
    We need pictures of that MOWER !!!!!! lol
    1996 Suburban K3500 SLT DUALLY
    1988 Camaro RS 383 stroker LT1
    1992 32' Aero-tek Race Boat, 600 CI BBC
    WE CAN STICK A DIESEL IN ANYTHING
    SPECIALIZED IN CUSTOM CONVERSIONS OF ANY KIND
    Scott:glasses:
  8. #18
    I did mine about 1.5 years ago I used Mobil 1 75-90 in both front and rear with no additive in my 2008 NBS. And Valvoline syn ATF for xfer case. I have the AUTO as a option on my 4x4 selector knob if that helps. But Now I am a big beliver on Amsoil after doing a full trans flush with their low viscosity ATF 12 quarts.
  9. #19
    Quote Originally Posted by afireinside View Post
    Count yourself lucky your transfer case hasn't failed. The Valvoline full syn ATF is good stuff, but it's the wrong product for your transfer case. I'm guessing you don't use the Auto4hi setting much. The only fluid to run in an AutoTrac case is GM's own AutoTrak II fluid. The blue stuff. It has specific friction modifiers and additives to withstand the incredibly fast clutch cycles of the T-case. I believe it's about $10 a bottle, and you only need two.
  10. #20
    Quote Originally Posted by 2COR517 View Post
    Well I am looking at my owners manual right now after reading your post and my trucks manual states Transfer Case(Four wheel drive) Dextron -VI Automatic Transmission Fluid
    So the Valvoline Dextron VI ATF Synthetic is correct I use the AUTO most of the winter. I wonder if the old body style uses Autotrack?
Similar Threads
  1. Rear Diff Fluid 2003 Silverado 4x4
    By ChevyBoy2009 in forum Maintenance & Upkeep
    Last: 01-17-2011, 03:44 PM
  2. How do I change the fluid in my transfer case and diff?
    By blackrat in forum General Chevy & GM Tech Questions
    Last: 06-09-2010, 08:09 PM
  3. Would you change it, or would you leave it? Rear diff fluid
    By zuper8 in forum General Chevy & GM Tech Questions
    Last: 05-13-2010, 07:21 AM
  4. Front & Rear Diff and Transfer Case Fluid Change
    By al96chev in forum General Chevy & GM Tech Questions
    Last: 11-24-2009, 11:12 PM
  5. question about rear diff fluid change
    By parks31 in forum GM Powertrain
    Last: 02-15-2008, 03:04 PM
