Results 1 to 9 of 9
    Default kmc wheels on silverado?
    I have an 07 new style body silverado, not lifted or leveled, and am looking at getting new rims without having to lift my truck and kmc's are the only ones i like, i want to get 18 or 20's if possible and am looking at the hoss or addicts by kmc with nitto terra grapplers, anyone run the same setup on an unlifted 2007 or newer silverado?would 20's be to big and just cause problems?please help
    Welcome to the club! No the wheel size will be fine but you will have to run a lower profile tire if thats the look your going for. I agree by the way. I love the KMC Addicts!
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
    Oct 2010
    Cobourg, Ontario, Canada
    wlecome to the club----I noticed that ntbush said that you might have to go to a lower profile tire if you go larger in size, and I'm not sure if you have ever drove on low profiles ??---they feel great to the road, but I found a pair we had as a little rough for everday driving.(just my own observation)-----good luck from Canada
    As long as you go with a setup close to stock you shouldn't have any issues. It is when you plus size you might run into issues. So if you want to run 20" wheels, find some that have the same offset of the stock rims. You can check out these threads that will answer a lot of questions and let you figure out what will and won't work.
    Both of those wheels should work, and I wouldn't go any bigger then a 275 tire.
    http://www.gmtruckclub.com/forum/sho...ft-Requirement
    http://www.gmtruckclub.com/forum/sho...ze-Calculators
    http://www.gmtruckclub.com/forum/sho...r-Measurements
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Welcome to the Club!!!
    TIRES:
    BFG All Terrain KO 315/70/17
    Sr. Apprentice Dontlookforme's Avatar
    Metairie, Louisiana
    The 20" rims will fit! Just make sure u get the right back spacing for your truck (if u are thinking of a lift in the future, find out what back spacing u might need for that!)275/55/20 tires are what are commonly found on new style body trucks!
    2006 silverado 1500 LT1 4X2 ecsb 6.0L, front mount T76 turbo intercooled, Detroit true trac, 3.23, Chevrolet black chrome 20"s, Nelson performance tune! magna flow muffler with dual exhaust with QTP cut out. ET-14.001 @100mph spinning.....
    I would really suggest to pony up and get the leveling kit to. I think it looks much better when your can run a bigger tire than stock with the 20's.
    Quote Originally Posted by ntbush83 View Post
    X2!! I would recomend at least a 1.5" level.
    Legend Bigbomber's Avatar
    Feb 2010
    Winnipeg,Manitoba,Canada
    X3 on the leveling kit or levelling shocks if your going to run 20's,welcome!
  1. Wheels for 08 Silverado
    By Rubicon500 in forum Lifted & Offroad Suspension
    Last Post: 05-25-2010, 07:23 AM
  2. ss wheels on 07 silverado?
    By rust4 in forum Lifted & Offroad Suspension
    Last Post: 09-18-2009, 08:40 PM
  3. he wheels on my 06 silverado 4x4
    By streetfighter in forum Member Introductions
    Last Post: 05-11-2009, 01:35 PM
  4. PLEASE HELP 06 Silverado wheels
    By nickt6494 in forum Lifted & Offroad Suspension
    Last Post: 11-27-2008, 11:37 AM
