Thread: It's alive!
    Default It's alive!
    I finally got my truck going. It sat for at least 3 years and before that it was only used around a farm. I had to replace the drivers side tank and sending unit, fuel pump, a ton of cracked hoses, the battery and alternator. I also changed the oil and anti freeze of course. It ran really rough so I added a can of sea foam to the 5 gallons of gas and revved it hard for a while. The sea foam did it's job and now it runs smooth. The tranny is leaking from the shifter seal so that will be next when it warms up a little from the below zero temps we are having. There is still a lot to do but it's running now and a blast to drive! One more Chevy saved from the wrecking yard! Future plans include-replacing a bad valve seal, drain and replace the brake fluid, power wash the motor and put on new valve cover gaskets, clean and rattle can the underside , roll on bed liner, tires and put a working stereo in. Next year I'm thinking big block, big tires and big axles.
    84 Chevy 1/2 ton Rathdrum ID
    Glad to hear it works! Got any pics of your truck? Oh, and welcome to the GMTC
    Nice! I'm glad you've got a truck you can use!
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Sounds like you have been busy...congratulations!!!
    TIRES:
    BFG All Terrain KO 315/70/17
    Legend Bigbomber's Avatar
    Feb 2010
    Winnipeg,Manitoba,Canada
    Real glad you shared that with us.Another reason why CHEVY trucks rock.
    murdog94's Avatar
    Well sounds like your close enough to a full restoration.. might as well swing in the BBC!!
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. WANTED: ALIVE ..JVC Face Plate
    By CallBob in forum General Classifieds
    Last: 09-09-2010, 07:21 AM
  2. Its alive and not leaking
    By cobra2end in forum General Chevy & GM Tech Questions
    Last: 04-17-2010, 05:45 PM
  3. How best to keep Tranny alive?
    By trapper_canada in forum GM Powertrain
    Last: 10-23-2009, 02:43 PM
  4. GoFastPadre is still alive
    By GoFastPadre in forum The Coffee Shop ~ Chit Chat
    Last: 02-17-2009, 06:47 AM
