Results 1 to 2 of 2
    Default 04 Silverado Door Buttons Stopped Working
    Today I went to unlock my door with the key fob but the drivers side door would not unlock (passenger door works fine). After getting into the truck I checked the other buttons and none of them work (windows, heated seat, mirror, or locks). All buttons on the passenger door work fine. Any suggestions for what to look at?
    The problem most likely is the power going to the door. Check the fuses, but I would think the same fuse works both doors, but check them anyway. Read up on them in the owners manual. Find the hot wire to that door, you will probably have to get a wiring schematic to chase it down. Use a test light or multimeter to check for power. It may be a wiring problem to that door. Check the harness from the door to the body of the truck, near the door hinges, that is the place where it can be the most easily damaged. Check all the plugs and connections on that wiring harness, and the back side of the fuse block, look for good tight connections. Good luck.
  1. Cruise control stopped working on my 2007 Silverado - no warranty left
    By Sportmod5 in forum General Chevy & GM Tech Questions
    Last: 11-01-2010, 10:03 AM
  2. 4x4 stopped working
    By nvyseal11 in forum Lifted & Offroad Suspension
    Last: 11-29-2009, 07:02 PM
  3. 04 silverado temp/compass stopped working
    By drumm14 in forum Audio, Video & Gadget Tech
    Last: 05-26-2009, 05:24 PM
  4. 88' Z71 4wd stopped working
    By Jagerballs in forum Chevy C/K Truck Forum
    Last: 03-05-2009, 02:02 PM
  5. '03 Silverado, cigarette lighter stopped working
    By gtilley45 in forum Audio, Video & Gadget Tech
    Last: 02-09-2009, 08:52 AM
