Results 1 to 10 of 13
    Default Switched accessory power for '11 Silverado
    I am trying to add a phone cradle and cell booster to my new truck but need to find a 12v switched power source. Where is the best place to pull the power from? I have heard people say that the distribution center by the brake pedal is the best but i am not sure if this truck has it as I have not looked. Has anyone had to get switched power and has a known good spot for it?
    Thanks!
    Check out the response at the top of page 2 on this thread. This should be about the same for a 2011.
    http://www.gmtruckclub.com/forum/sho...r-Wire-Needed!
    -Sal
    Desert Brown Metallic
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Thread looks spot on Troutbug!
    Welcome to the Club Hamel!!
    TIRES:
    BFG All Terrain KO 315/70/17
    Yes, welcome too. I didn't notice that this was your first post. Mike, I remembered that thread because I learned something from it too! Not bad for an almost middle-aged dog, huh?
    Thanks everyone! Just to let you all know the '11 has the same power hook up spot as the '08 did so that post helped alot! Got everything in and works great!
    Thanks again!
    Quote Originally Posted by hamel01 View Post
    Thanks again!
    I have a 2011 Chevy Silverado 1500 and am trying to install a radar detector. I can't find a switched power source to save my life. After seeing this post I tried to find the pin on the distribution box to the left of the brake pedal but for the life of me can't figure out how to get the plastic cover off it. I pulled and pried the edges up but it appears there is some fastener in the middle of the cover which looks like it is going to break if I keep pulling. I actually seen metal bending from pulling on the plastic cover so hard.
    Anyone know how to get the cover off so I can get to the switched power connection?
    Thanks,
  1. Switched power source in '09 Silverado
    By Cussmotor in forum GM Electrical Tech
    Last: 01-08-2011, 12:08 AM
  2. '02 switched power source
    By KidHauler in forum GM Electrical Tech
    Last: 05-16-2010, 08:04 PM
  3. Need to find Switched power on 07 Silverado
    By Kirbbsster in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-01-2010, 08:47 AM
  4. Switched Power??!??
    By Silvercat in forum Audio, Video & Gadget Tech
    Last: 09-24-2009, 09:28 AM
  5. Favorite switched accessory lead??? Anyone?? [Expired Topic]
    By MN_Burbon in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 08-25-2005, 10:42 AM
