Results 1 to 10 of 13
    Default Switched accessory power for '11 Silverado
    I am trying to add a phone cradle and cell booster to my new truck but need to find a 12v switched power source. Where is the best place to pull the power from? I have heard people say that the distribution center by the brake pedal is the best but i am not sure if this truck has it as I have not looked. Has anyone had to get switched power and has a known good spot for it?
    Thanks!
    Check out the response at the top of page 2 on this thread. This should be about the same for a 2011.
    http://www.gmtruckclub.com/forum/sho...r-Wire-Needed!
    -Sal
    Desert Brown Metallic
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Thread looks spot on Troutbug!
    Welcome to the Club Hamel!!
    TIRES:
    BFG All Terrain KO 315/70/17
    Yes, welcome too. I didn't notice that this was your first post. Mike, I remembered that thread because I learned something from it too! Not bad for an almost middle-aged dog, huh?
    -Sal
    Thanks everyone! Just to let you all know the '11 has the same power hook up spot as the '08 did so that post helped alot! Got everything in and works great!
    Thanks again!
    Quote Originally Posted by hamel01 View Post
    Thanks again!
    I have a 2011 Chevy Silverado 1500 and am trying to install a radar detector. I can't find a switched power source to save my life. After seeing this post I tried to find the pin on the distribution box to the left of the brake pedal but for the life of me can't figure out how to get the plastic cover off it. I pulled and pried the edges up but it appears there is some fastener in the middle of the cover which looks like it is going to break if I keep pulling. I actually seen metal bending from pulling on the plastic cover so hard.
    Anyone know how to get the cover off so I can get to the switched power connection?
    Thanks,
    bottom tab should either push in or pull out and plastic cover slides off. If I get a chance I'll find a pic.
    or two tabs on both sides you push in and cover should pull out.
    to put it back on, just slides on tell it clicks back in place.
    Quote Originally Posted by randomsandwhich View Post
    Any more on this as I've pride all four sides up and it won't budge as there seems to be a fastener right in the center with a flat head that is keeping it from being removed?
    Thanks so much for your help.
    sorry for the late response, in the middle of moving but here you go. It seems your might be different. To take mine off, i reach behind and pull outer cover outward and pull out. It took me sometime to figure out. Sorry for the misleading information from my last post. Here is some pictures. If yours is differnt not sure then.
    Thanks so much for posting the picture. Mine looks just like that except it has a fastener directly in the middle and when you pull on the cover you can see this fastener is keeping it from releasing. I'll take a picture of mine tonight after I get home from work.
    Thanks a million for all your help.
  1. Switched power source in '09 Silverado
    By Cussmotor in forum GM Electrical Tech
    Last Post: 01-08-2011, 12:08 AM
  2. '02 switched power source
    By KidHauler in forum GM Electrical Tech
    Last Post: 05-16-2010, 08:04 PM
  3. Need to find Switched power on 07 Silverado
    By Kirbbsster in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-01-2010, 08:47 AM
  4. Switched Power??!??
    By Silvercat in forum Audio, Video & Gadget Tech
    Last Post: 09-24-2009, 09:28 AM
  5. Favorite switched accessory lead??? Anyone?? [Expired Topic]
    By MN_Burbon in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-25-2005, 10:42 AM
