Results 1 to 9 of 9
Thread: tbi injectors
    Default tbi injectors
    im wanting to put the bigger 454 injectors on my 350 my question is if the injector pods are the same size. what i mean is if i can pull the injectors out of the 454 pods and put them in the 350 pods my reason is that the fuel inlet on the 454 pods is broken. any info will help guy thanks.
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    If you do the swap, you may have to change the fuel pump, so you get more pressure.
    yeah i was told that a adjustable fuel pressure regulator will take care of the pressure difference i just need to know if the pods are the same
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    Sorry I don't know the answer to that. :(
    thats alright thanks. i have talked to a bunch of different people and noone seems to know the answer
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    See if murdog replies...
    He usually has a good handle on these things.
    Try TurboCity.com, they do alot of TBI mods.
    GM used 3 TBI housings, the 454 got a larger bore than the 4.3 & small block V-8's and the 2.8, 3.2 & 3.4 v-6 was the smallest.
    The 4.3 injectors did fit into the smallest TBI housing when I put the 3.4L crate engine in my S-10. The only difference was the flow rate...
    I remember that the TBI ECM could handle up to a 10% increase in displacement and going from a 2.8 to a 3.4 was more like 20% so I went to the 4.3L injector to fool the 2/8L ECM...
    The injectors are the same size. The small block TBI housing is not the same throttle bore size as the big block. I would be concerned over the higher flow rate if you have not modified your engine's ability to breath better you will be running too rich.
    2006 Impala LT 3.5L
    thanks for the info wis bang. i have dramatically increased the flow of my engine i have put cold air intake eddlebrock performer intake manafold cam full length headers and true dual 2.25 inch exhaust. im going to pull the injectors out this weekend and install the big block injectors and see what i end up with that is if summit sends me my fuel pressure regulator tomorrow.
  1. TBI Injectors
    By ajkourafas in forum Performance & Fuel
    Last: 12-07-2011, 07:43 PM
  2. Fuel Injectors
    By Guamrock in forum Performance & Fuel
    Last: 04-11-2010, 08:08 PM
  3. Noisy Fuel Injectors??
    Last: 03-15-2010, 12:35 PM
  4. bad injectors vs particulate filter
    By bowtiebrian in forum GM Powertrain
    Last: 08-11-2009, 08:21 PM
  5. 90 3/4 ton injectors not firing
    By bigjunk93yj in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-29-2009, 07:17 AM
