    Default frankenstein van no injector pulse
    After getting my engine swap complete, I have no injector pulse. Have power to the injectors, have spark, have fuel pressure. Just no pulse. I know the computer is/was good when pulled from the donor vehicle. My gut is that computer isn't receiving signal from the dist (not reading rpm) and therefore not firing the injectors. Will be building a datalogging harness shortly to see if engine RPM is being read, as well as testing sensors. Any suggestions are appreciated.
    Engine/computer is an OBD1/TBI setup from a 92 GMC Yukon 5.7L
    got ahold of diagnostics manual info, hooking a test light clip to 12v, and tapping the purple/white wire on the 4 pin dist harness with the probe (IC Reference High), it should create a test signal and fire the injectors. Hoping to test it tonight, if the weather isn't too bad.
    well apparently was just a bad connection on the harness into the distributor. The diag test yielded injector firing properly, and upon reconnection had injector pulse! Nice when it's an easy fix
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Nice!! It's great hearing about those "easy" fixes.
    TIRES:
    BFG All Terrain KO 315/70/17
  1. 1990 305 no injector pulse
    By kcfocus1 in forum General Chevy & GM Tech Questions
    Last: 09-02-2010, 10:30 PM
  2. Turn Signal problem.. doesn't pulse..
    By Falcone in forum General Chevy & GM Tech Questions
    Last: 10-29-2009, 11:20 AM
  3. Will a 86 wiper motor w/ pulse board drop into my 92? (Sonoma)
    Last: 08-03-2009, 10:58 PM
  4. idle pulse
    By grog in forum General Chevy & GM Tech Questions
    Last: 04-14-2009, 08:00 AM
  5. Wiper pulse delay module
    By hunterdmg in forum General Chevy & GM Tech Questions
    Last: 08-24-2008, 03:14 PM
