GM Truck Club
Results 1 to 4 of 4
    Default hard start 88 silverado
    my 88 silverado is hard to start when cold. I changed the plugs, wires, distrubutor, rotor no improvment. I did notice that when oil gauge is all the way up the truck starts up. can this be the oil pump or a sensor?
    Legend
    murdog94's Avatar
    Feb 2008
    Cloquet, Minnesota, United States
    Sounds more like you need to check the fuel pressure, and a seafoam treatment, also consider doing a TBI rebuild kit since it may have never been done and the FPR tends to wear out over time.
    Mike
    Currently
    1997 Chevy S-10 Blazer 4X4 with 330K miles and counting (Hunting rig).
    2009 Saturn Aura XE (wifes car)
    2011 F-150 Crew 4X4
    "Hold it to the floor till you see God.... Then Brake!!!!"
    thank you will try a TBI rebuild
    Had similar issues with an '87 TBI 350. Problem started after replacing one of the fuel tanks (including the pump and sending unit). It would also run rough just off idle...
    I guess I knocked some old crud loose in the affected fuel lines and partially plugged the fuel filter. Swapped the filter, Seafoamed it, ran the hell out of it, then swapped the filter again to fix it.
    2010 Silverado Extended Cab 4X4 LTZ w/Z71
    2008 Tahoe 4X4 LT w/Z71
    1987 R10 Silverado 2wd short-bed (Wonder-Truck!)
    The only mustang in our house.... A NAVY MUSTANG!
Similar Threads
  1. Help with a hard start issue...
    By alchemist1 in forum GM Powertrain
    Last: 10-25-2010, 08:45 AM
  2. 98 k2500 hard start
    By SHOOTER- in forum General Chevy & GM Tech Questions
    Last: 10-12-2010, 06:14 AM
  3. Hard/No start when Cold outside
    By THEEDGE714 in forum GM Powertrain
    Last: 10-29-2008, 03:51 PM
  4. hard to start 2000 silverado
    By jasonsz71 in forum General Chevy & GM Tech Questions
    Last: 07-15-2008, 05:48 PM
  5. Hard to start suburban
    By ftwken in forum GM Powertrain
    Last: 01-09-2008, 03:51 PM
