    Default hard start 88 silverado
    my 88 silverado is hard to start when cold. I changed the plugs, wires, distrubutor, rotor no improvment. I did notice that when oil gauge is all the way up the truck starts up. can this be the oil pump or a sensor?
    murdog94's Avatar
    Sounds more like you need to check the fuel pressure, and a seafoam treatment, also consider doing a TBI rebuild kit since it may have never been done and the FPR tends to wear out over time.
    Mike
    Currently
    2011 F-150 Crew 4X4
    thank you will try a TBI rebuild
    Had similar issues with an '87 TBI 350. Problem started after replacing one of the fuel tanks (including the pump and sending unit). It would also run rough just off idle...
    I guess I knocked some old crud loose in the affected fuel lines and partially plugged the fuel filter. Swapped the filter, Seafoamed it, ran the hell out of it, then swapped the filter again to fix it.
    2010 Silverado Extended Cab 4X4 LTZ w/Z71
    2008 Tahoe 4X4 LT w/Z71
    1987 R10 Silverado 2wd short-bed (Wonder-Truck!)
    The only mustang in our house.... A NAVY MUSTANG!
  1. Help with a hard start issue...
    By alchemist1 in forum GM Powertrain
    Last Post: 10-25-2010, 08:45 AM
  2. 98 k2500 hard start
    By SHOOTER- in forum General Chevy & GM Tech Questions
    Last Post: 10-12-2010, 06:14 AM
  3. Hard/No start when Cold outside
    By THEEDGE714 in forum GM Powertrain
    Last Post: 10-29-2008, 03:51 PM
  4. hard to start 2000 silverado
    By jasonsz71 in forum General Chevy & GM Tech Questions
    Last Post: 07-15-2008, 05:48 PM
  5. Hard to start suburban
    By ftwken in forum GM Powertrain
    Last Post: 01-09-2008, 03:51 PM
