    Default Outside Temperature Reading Incorrect
    Hi. Wasn't sure where else to post this but my outside temp reading on my mirror seems to be way off. This morning our actual outside temp was around 0 to 1 degrees but the reading inside the truck said -7. The owner's manual doesn't seem to offer any help other than bringing the truck in for service.
    Anyone else experiencing this in cold temps? I know the compass can be calibrated but it doesn't appear the temp portion can be. I was already 10 minutes into my drive to work so I think the reading had plenty of time to adjust.
    Thx
    2004 Chevy Silverado 1500 w/ext cab and stepside bed.
    I have noticed now that it is colder that it takes the truck a few miles down the road to get to the true temp. I knew it was about 25 this morning and the truck said 34 when I got in and maybe 3 miles up the road it dropped to 24. I can't remember if the truck did this in the past, but just noticed it this week.
    Quote Originally Posted by ajarman View Post
    I figured that was probably part of the issue but I think the temp was still 5 or so degrees off even when I got to work (30 min drive).
    My 2008 does that as well, also on occasion if I leave my truck to warm up for an extended amount of time with max heat on defrost for awhile, the temperature will go up to 112 when its only 30-40 outside. But its not just GM's .. other vehicles of different make do this as well.
    yeah not super accurate but i think it gets close after driving. never seen the initial temp to be accurate. oh yeah and thats frickin' cold.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Ok, maybe I'm expecting too much from this thing. I know my other vehicles have been more accurate; within +/- 2 degrees at the most.
    My 2010 has a temp display reading on the computer and it is pretty much perfectly accurate at all times. Whenever I see another temperature displayed at a bank or other business it is always the same or close to that temp. Within a degree or two if there is a difference. So I consider that pretty good.
    ---------- Post added at 05:02 PM ---------- Previous post was at 04:56 PM ----------
    You did say ACTUAL outside temp was 0 to 1 degrees but are you sure? What are you cross checking your vehicles temperature reading against? Are you comparing it to an actual accurate digital thermometer that you know to be precisely accurate? Or are you just going by what the weatherman says the morning outside low temperature SHOULD be? Because temps can and do vary by 7 degrees easily. It could easily be actually colder than you thin k it is.....just sayin.
    Quote Originally Posted by stinger44 View Post
    Thx
    2010 GMC Savana AWD
    Silver Metallic, 5.3L, 3.73 Gears and G80 Heavy Duty Locking Rear Differential, American Racing Off Road Series ATX Chrome Assaults 17X8, BFG T/A KO's 245/70/17 (Stock Size).
    Alpine ida-x303 head unit, Alpine Power Pack, Alpine SPS-600 Speakers
    Viper 350HV car Alarm
    Coverking Neoprene Seat Covers
    42" Slider Windows
    Custom Bed with 6" Memory Foam Mattress
    Avery Berber Carpet
    the sensor for the thermometer is in front by the radiator, if you park in the sun or have it running When parked you won't get a accurate reading
  1. oil pressure reading
    By henrys021500hd in forum GM Diesel & DuraMax
    Last Post: 10-27-2010, 09:19 PM
  2. Oil pressure reading???
    By philosofy1 in forum GM Powertrain
    Last Post: 01-11-2010, 01:54 PM
  3. DIC MPG reading
    By Coneklr in forum General Chevy & GM Tech Questions
    Last Post: 09-07-2009, 03:06 PM
  4. SES light, no temp reading
    By hockeyham in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 10-30-2008, 12:29 AM
  5. map reading lights
    By dtalsma in forum Audio, Video & Gadget Tech
    Last Post: 01-19-2008, 12:12 AM
