Thread: Dead battery
    Default Dead battery
    Ok, battery is so dead, remote unlock won't work and just found out the key won't go in the door lock....what are my options now????
    murdog94's Avatar
    reach up inside the grill from the bottom and pop the hood latch.. Ive had to do this a LOT of times with new GM trucks when i was driving a wrecker. Then you jump the truck off so you can hit the keyless or at least turn the key... Then jump the truck off and find out why the battery went dead.
    Mike
    Currently
    2011 F-150 Crew 4X4
    stephan's Avatar
    Far West, Oregon USA,
    X2 what Murdog said, even though it might be difficult for you.
    Option 2.. If you can't access your hood latch to gain access to charge your battery, you can charge your battery through your trailer wireing B+ lead IF you remember which one it is, & then hook your chargers ground clamp to a clean chassis ground.
    All this techno stuff is convienent & really great, untill Onstar tells you "sorry" we can't help you with this particular problem & then it just becomes a P.I.A. & the difficulty factor far outweighs the convienence. ha ha ha
    This is one reason you should put a tag wire on your hood latch so it can easily be hooked with a screwdriver, another piece of wire, or even a stick found alongside the road, not only because of remote/power door locks, & a dead battery, but because hood release cables tend to break at the most inopprotune times. Make it only long enough that you can barely reach it with your tool of choice. This will leave it far enough back in there & well hidden, so that auto & battery thieves won't see it.
    3" susp. lift kit "shadetree"
ID:	23146 hope this helps!
    Mike - SoCal
    07 Sierra 1500HD
    Ultra Mammoth Wheels 17x8
    Nitto Terra Grapplers - 305/70/17
    Line-X Bedliner and Wheel Wells
    NFab Nerf bars
    CST 4" Spindle lift
    08 Hybrid Tahoe - wifey's ride
    McGaughy's 2/3 drop kit
    22x9.5 Tyfun Wheels
    Nexen Roadians 285/45/22
    OK, what if i put positive to the 12+ of the the trailer hitch and negative to the chasis, will it give me a chance to unlock the doors that way?
    stephan's Avatar
    It depends on the amprege output of your battery charger & just how dead your battery really is, as far as whether it will do it immediately. Be patient as it may take 10-20 minutes for it to build the battery up far enough to actuate them.
    May 2010
    Idaho Falls, Idaho
    Dude 1 word... locksmith. (or is that 2 words? lol) Anyways, good luck! I never knew you could charge the battery from the trailer wiring??? Good to know.
    2002 Sileverado 1500, Ext. cab, short box, 5.3l, Z71
    Cignito Leveling Kit
    Bilstein Shocks
    ANZO projector headlights with halo's
    Various brand L.E.D. tail lights, turn signals, & 3rd brake light
    Smoked fog lights
    285/75/R16 BFG All-Terrain T/A KOs
    16" Pro-Comp 7089 rims
    Custom 2-tone Flat-Black/Stock-Red Paint
    Viper 5701 Responder LE Remote Start System
    WeatherTech FloorLiner floor mats
    Not looking to charge the car, just to get enough power to it to get the remote door locks to open, and then pop the hood, and then charge it or replace the battery.........
    locksmith will slim jim the truck, or wedge the door at the top and slide something to slide the lock open, I can do that, but always risk of damaging something
    murdog94's Avatar
    Quote Originally Posted by coppcarz View Post
    A lock smith cant get in either, the actuators are not able to be pulled without battery voltage, and getting the wedges in damages them. Honestly the fastest and easiest way is reach up and in and pop the hood..
    I had this problem ALOT when working with GM when i was driving a tow truck in 2009... We would get all of the dealer calls on this, and show up thinking it was an easy unlock.. Only to find out we have to climb under the truck and reach up (not very comfortable) to pop to hood.
    Being lazy in nature paid off, on the Tahoe, look inside the grill, above the bow tie emblem, you will see the end cap of the hood release cable, get a long flat head screw driver, push onto the tab where that cap is resting, to the right, and hood pops right up......
  1. dead battery !
    By loic in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 08-31-2009, 07:01 PM
  2. dead battery?
    By vegaschevy in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-23-2009, 08:27 PM
  3. Dead Battery
    By starultra in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 02-22-2009, 06:23 PM
  4. Can't recharge my dead battery
    By areotreker in forum Audio, Video & Gadget Tech
    Last: 11-03-2008, 06:36 PM
