    Default how to remove a 95 k1500 dashboard??
    If anyone has ever successfully removed an entire dashboard out of a 95 or 96 truck, please let me know what to do... my dash is pretty banged up and I wanted see what I could do about fixing it... possibly replacing it.. thanks you guys!
    murdog94's Avatar
    U will find there are two bolts on each side bellow the dash behind the plastic covers. You need to undo those, then there are 7mm bolts up by the windshield that have to be done. You will need to remove the lower plastic below the steering column, and unbolt the steering column. You will also have to undo the bolts for the wiring harness and unplug as you go. Honestly it would be best to get a chiltons manual... It really isnt hard but just remebering where everything hooks up can be. And just take your time..
    Mike
    Currently
    2011 F-150 Crew 4X4
    Thanks mike
    murdog94's Avatar
    Oh make sure that you have a second set of hands, and just take your time because once you have those bolts undone your dash will be loose and the only things holding it in will be the wiring harness.
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. Plastic fender flares... to Remove or not to remove
    By Big_Ben in forum Chevy Truck Accessories
    Last Post: 02-10-2013, 10:18 PM
  2. Replies: 0
    Last Post: 07-30-2010, 07:00 PM
  3. Behind the dashboard
    By Metaluzc in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-11-2010, 05:49 PM
  4. dashboard
    By lowriderinms in forum General Chevy & GM Tech Questions
    Last Post: 12-20-2009, 09:26 PM
  5. Dashboard
    By lmin2 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-26-2008, 06:41 PM
