    Default 4x4 actuator - 2008 Silverado HD
    where is this located? I am looking for this and need a little help, thanks
    :great:Semper FI
    2008 Vortec 6.0 LT Z-71
    2500 HD "BIG BOY" Truck
    Stealth Grey Metallic
    Volant Cold Air Intake
    Line X Bed liner
    265 75 R16 Michelin LTX M/S2 ORWl
    Chrome step bars
    Fog lights
    3M clear shield hood protector
    Putco over sized boss locker side rails 2 1/2"
    Truxedo Low Pro QT Tonneau Cover
    Can you be specific about which actuator you are referring to? I can think of 2 parts that could be called "4x4 actuator:"
    1) the mechanism on the transfer case that "shifts" the transfer case. T-case is the thing located behind the transmission with the driveshafts coming out of it. You don't say if you have a lever/manual shift transfer case or an electric shift, but the shifting mechanism will be attached to the transfer case.
    2) the center axle disconnect (CAD) on the front differential. I believe it is usually near the place where the driveshaft attaches to the differential.
    i have a turn style knob, automatic.
    ---------- Post added at 11:01 AM ---------- Previous post was at 10:31 AM ----------
    Ok so I found the actuator , unplugged it but no good. I guess it is off to the shop on mon am.....:(
    turns out it was not the actuator....it was a broken front end....:(
    How did you get the 4X4 switch out to unplug it?
  1. no power to actuator
    By gregt in forum General Chevy & GM Tech Questions
    Last: 08-26-2010, 04:36 PM
  2. actuator stuck on heat/ Air not cooling on 2007 Chevy Silverado
    By heathaa0 in forum General Chevy & GM Tech Questions
    Last: 08-21-2010, 04:39 PM
  3. 4wd Actuator not engaging
    By gt1009 in forum GM Powertrain
    Last: 07-03-2009, 06:20 PM
  4. 1989 Silverado 4WD actuator question
    By WPG in forum Chevy C/K Truck Forum
    Last: 02-25-2009, 09:11 PM
  5. mode door actuator 99 silverado
    By mgod12878 in forum General Chevy & GM Tech Questions
    Last: 11-05-2008, 08:11 AM
