Thread: manual swap out
    Default manual swap out
    Has anyone taken out a manual tans and put it in there burb?
    1997 Chevy Burb 2500 4x4 - 454 (7.4L)
    265/75/162 BFs ATs
    Fule consumption 9 HPM -- (Hippies Per Mile)
    Fav accessory on it --- dirt and mud
    "Yes its virtually a tank and yes by god I drive like it is one too"
    murdog94's Avatar
    There has been a member or two. Be thing that i can recomend is to buy a donor truck (K2500) and transfer over all of the parts. This will ensure that you have all of the needed parts at hand. There is already a spot stamped into the floor for you to cut out for the shifter to go thru. but the Donor will have the PCM, wiring, and slave cyl, and master cylinder stuff that you will want.. ir really is as easy as unbolt from one truck and bolt into yours. For the most part there isnt any fabrication needed.
    Mike
    Currently
    2011 F-150 Crew 4X4
    i notice that the the 3/4 ton 4x4 trucks have the 4wd shifter on the floor, my burb is push button electronic, are my suspicions right in that it will complicate/prevent a swap out ?
    murdog94's Avatar
    No your transfer case will bolt to the manual tranny just fine.
  1. Manual Door to Electric Door swap how to ???
    By omarrufo in forum General Chevy & GM Tech Questions
    Last: 10-08-2009, 02:03 PM
  2. rear end swap or gear swap
    By rmagni in forum GM Powertrain
    Last: 08-18-2009, 07:42 PM
  3. 04 Manual
    By MBurke in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-23-2009, 05:21 PM
  4. manual auto swap
    By mattyV in forum General Chevy & GM Tech Questions
    Last: 11-19-2008, 12:51 AM
  5. 99 diesel suburban I NEED a manual + owners manual supplement for diesel!!
    By hogair in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-21-2007, 11:33 PM
