    Default Error code P0141
    I have the dreaded 02 Heater Circuit Bank 1 sensor 2 error code. Has anyone know which 02 sensor will fix this. I have a 2000 LT1500 Suburban.
    It is the drivers side exhaust pipe, second O2 sensor down.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    Default Thanks
    Gary, thanks for the info. Does it have a name so I can ask for it at the auto part store? Or is this a dealer item? Easy to change?
    It's just called an O2 sensor. Tell the parts store which one you need and they should be able to fix you up. They are usually easy to replace if they are not rusted in place. You might try to spray it with some rust buster before you start, but make sure the pipes are cool first.
    Default Fixed
    Thanks for your help. It was a piece of cake. Swapped out the sensor and then had the codes erased. No light? So I think it is fixed!!
    THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    http://mysite.verizon.net/vze7erz1/id16.html
    This web site has dual o2 bypass for only $25 plus shipping. I have used this on my farm rig way cheaper than replacing o2 only works for o2 downstream from cat though. Just sends a signal saying the o2 is working and keeps everything in check
  1. Error code P0411
    By pj08tb in forum General Chevy & GM Tech Questions
    Last: 01-26-2013, 11:21 AM
  2. P1415 Error code
    By musclebound in forum General Chevy & GM Tech Questions
    Last: 11-08-2009, 09:17 PM
  3. Code Error
    By vemery1994 in forum General Chevy & GM Tech Questions
    Last: 10-04-2009, 03:33 PM
  4. Error code 39
    By Malsteem in forum General Chevy & GM Tech Questions
    Last: 09-02-2009, 03:23 PM
  5. Error code P0122
    By COSSilverado in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-22-2009, 05:21 PM
