    Default Cab Grounding Problem
    I have a 90 K1500 5.7L 5 spd that while the key is in the on position, ( engine on or off), all the gauges will "flutter" a little if an powered accessory with a switch (turn signal, hazards, pwr windows, pwr locks, headlights etc.) Some more than others. The oil pressure gage moves the most and the fuel gauge moves the least. The spedometer does not move at all. The temp and volt gages slightly "flutter". I believe this to be cab/chassis ground problem. But do not know where the proper ground would be. I checked the ground next to the battery, the instrument ground on the fire wall, and the three that I know of on the engine. Anyone else had this problem and possibly found a solution??
    Jr. Mechanic pychokenny's Avatar
    Jun 2010
    Parkin, Arkansas, United States
    my truck does it to so does my 93 so does my 89 i thank it a comman thing
    "U call we haul U bitch we unhitch.''
    "Gear grindin, Tire burnin, Diesel smoke blowin. Truck Driver."
    |^^^^^^^^^^^\||____
    | Pycho Kenny..... |||""'|""\__,_
    | _____________ l||__|__|__|)
    Fixed the problem somewhat, the gauges move a lot less now. There is a cab ground next to the battery that grounds to the "inner fender." I cleaned that up, cleaned up the engine block ground, the alternator ground and ground on the battery and it seemed to mostly cure the problem.
  1. Ah, there's the problem...
    By KidHauler in forum GM Powertrain
    Last Post: 03-11-2010, 11:16 AM
  2. Grounding Point for ECM 1989 Suburban
    By Big6ft6 in forum GM Electrical Tech
    Last Post: 12-23-2009, 03:08 PM
  3. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech Questions
    Last Post: 12-13-2009, 05:38 PM
  4. Possible Grounding Issue?
    By dewayne in forum Audio, Video & Gadget Tech
    Last Post: 10-07-2009, 09:02 PM
  5. 4WD Low problem 06 Z71
    By APSK7429 in forum General Chevy & GM Tech Questions
    Last Post: 11-30-2008, 08:02 PM
