Thread: po171 and po174
    Default po171 and po174
    Ok so a few weeks ago the cel came on and it was 171,174, and another which was the maf. so i changed the maf and they went away for about a week then came back on. ive sprayed carb cleaner and found nothing. The fuel filter was also changed about 2 months ago. so if someone can point me in a direction that would be great. Also if it really cold outside the truck idels really ruff until it gets warm.
    03 silverado ls model x-cab z71 w/ 5.3l.
    black lo pro toolbox
    ruff country leveling kit
    285/70/17 tera tracs
    stock 17's that are rhino lined
    5% tint
    could be your cat system ?!!!
    Scott:glasses:
    Quote Originally Posted by dshewy14 View Post
    I would Inspect all Vacuum and PVC hoses .....as there could be a Vacuum leak downstream of the MAF Sensor and lasted Check the Fuel Pressure.....Also you should use......CRC MAF Sensor Cleaner Only.....went cleaner the MAF Sensor.
    CRC 05110 Mass Air Flow Sensor Cleaner - 11 Wt Oz.
    Thanks guys Ima look at it tommorrow n c what I can figure out. And happy new years
    U can set a lean code on these motors by running w oil cap off. Need to check all stupid possibilities.there're also newer intake gaskets avail old orange ones have service bull.on them new ones should have green rubber
    2000 sierra 1500 5.3
    k&n cai
    hypertech programmer
    flowmaster catback
    7" lift 456' s. 35/12.5 nitto teragrapplers
    roll bar. Baha spare tire holder
    brush guard custom tail lights
    full sound system dvd nav
    well i got another new maf today and changed it, the pcv valve, and put new plugs and wires on. So far the cel has not come back on but after looking at the plugs you can tell its really running lean.
    Getting lean codes for both banks, and the spark plugs are confirming the lean condition. Next thing I'd probably do would be to put a fuel pressure gauge on it and make sure the fuel system is generating enough pressure.
  1. Help With Codes Po171, Po300 And Freeze Frame Data
    By jcwells in forum GM Powertrain
    Last: 02-20-2009, 09:45 AM
