    Default water temp gage not working, 99 tahoe
    on my 99 tahoe, the water temp gage just quit working, the needle will just go to the 1st line even when the engine is hot. how can I fix this ?
    Quote Originally Posted by loic View Post
    I would check......The Sending Unit and/or the Stepper Motor for the Water Temp Gauge.
    where are those located ?
    The sending unit is on the drivers side head. One lone wire coming down from the harness over the valve cover. There is a connector near the PCV valve. I believe the sending unit is between cylinders 1&3.
    Pretty easy to check the wiring and gauge. Remove the wire from the sender. The gauge should go all the way one direction, pretty sure it's to the cool side. Then touch the wire connector to the block or any other good ground. The needle should peg the other way. Assuming that all works properly, you can narrow the problem down to the sending unit, or thermostat.
    The thermostat is suspect if the gauge is moving at all. Do you have good heat in the cabin? If you let the engine warm up in the driveway, the gauge should come up to the 10 or 11 o'clock position, I forget the actual number LOL. If it goes way down once you start driving, the thermostat is your likely problem.
    ok, thanks,yes the heater is working fine. I'll try and check it tomorrow. thx for the infos !!!
  1. overheating/coolent/water temp guage?
    By capt sensible in forum General Chevy & GM Tech Questions
    Last: 08-22-2010, 09:02 PM
  2. 96 s10 Fuel, Water Temp and Voltage Gauges dont work!
    By rx7srlife in forum Chevy S10 Forum (GMC Sonoma)
    Last: 12-13-2009, 10:38 AM
  3. Help Putting in aftermarket water temp gauge
    By CJRM112 in forum General Chevy & GM Tech Questions
    Last: 11-20-2009, 01:54 AM
  4. Water temp cycling high and low
    Last: 07-26-2009, 09:50 AM
  5. Temp Guage Not Working
    By BIGFOOT in forum General Chevy & GM Tech Questions
    Last: 12-31-2008, 12:49 PM
