    Cool cd player won't eject in 2005 Colorado
    Hi
    my 05 canyon stock cd(single)player wont eject..I put a burned cd in it.it plays the songs but clicks rapitly several times and stops and says ck cd.any ideas on getting it out? many thanks...Fred
    Welcome to the G M T C ! I don't know if the Colorado has the same problems that the Silverado does, buy my '04 Silverado I traded in had a CD stuck it the radio. I was able to work with a knife and finally get one out, but the next time it was used it did the same thing. Maybe some of the other members will be able to help out, good luck!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Thanks for the tip...I'll give it a try.........btw This seems to be a excellent forum and i wiil enjoy beloning to it..Thanks again .......fred
    unhook the batt for about 1 hour and then try again.
    Scott:glasses:
    Hi...
    allready tried that.I stupidlly put a pc burnt disc in and from what i hear thats a no-no.going to try the knife trick and see if ican get it out that way...Thanks for the advise...Fred
    The stock HUs like to eat CDs after a while. Mine had a bought CD stuck in it.
    ~Dan
    2005 Chevy Colorado Crew Cab ZQ8 Xtreme
    My Colorado has a 6 disk changer in and mine did the same exact thing. i had 6 disks stuck in and and could do nothing to get them out. i eventually had to pull the HU out and open it manually to remove the CD's. I had combination of burned and bought CD's. I still have one left in whichi cant get to without destroying the radio.
    My 2010 Colorado single CD radio.
    Same issue.
    Radio replaced under warranty.
    I have the same problem with my 05 Colarado. Has anybody installed an aftermarket radio for this reason? If so what brand was it and did you have to do any modifications around the face plate.
    It depends on what you want, and how much you want to spend. There are a number of "good" after market stereo's. If you like to fiddle with settings and fine tune everything, then Kenwood Excelon's are one of the top brands. Do not get the regular line Kenwoods though. Kenwood stands behind their numbers (power ratings) and have allot of nice features.
    When I moved to Kenwood, their top of the line single DIN unit sold for around $699 now their top of the line single DIN unit is $299 + what ever the shop is going to charge you to install it.
    Now you can install it yourself. Typically you need 3 basic things on top of the new unit. 1. is the wiring harness adapter. Second is your antenna adapter, and last is the face plate kit.
    If you have special things like steering wheel controls, then another adapter is needed also.
    The nice thing about going after market in an older truck is 1. the CD player is usually better quality. My Kenwood Excelon KDC-X996 has Blue tooth (Hands Free Calling( that was not available back in 2000 on my truck); USB for Ipod/Ipad/ or USB drives with MP3's, WMA files, or ACC files. I forgot to mention it also has an HD radio tuner ( I use this allot around here),
    Kenwood also has an app I use on my andriod phone that connects over blue tooth if I want to stream music from the internet into my head unit or even mp3's on the phone.
    The only thing it does not have is a DVD or Blue Ray drive...... but plug the phone into a charger and mount it somewhere and you can watch movies on the phone with the sound coming through the speakers in the truck.
    Here are the features from Kenwood:
    General features:
    • CD receiver with AM/FM tuner
    • built-in MOSFET amplifier (22 watts RMS/50 peak x 4 channels)
    • plays CDs, CD-Rs, and CD-RW discs including discs loaded with MP3 and WMA music files
    • built-in HD Radio tuner
    • built-in Bluetooth for hands-free calling and audio streaming
    • fold-down detachable face with selectable 5- or 3-line line display, plus variable display and control colors
    • remote control
    Audio features:
    • 13-band equalizer
    • Sound Excellence DSP with speaker size settings, plus high- and low-pass crossovers
    • digital time alignment
    • Supreme Setting improves the sound of files encoded at low bit rates
    • bass boost
    • subwoofer controls
    Expandability:
    • iPod/iPhone direct control via USB input — no adapter necessary, but adding Kenwood's optional connecting cable lets you leave your iPod cable at home
    • Pandora control with iPhone, Android, and Blackberry
    • compatible with Kenwood's Music Control app for Android phones
    • compatible with SiriusXM tuner
    • inputs: rear auxiliary and USB inputs
    • outputs: 6-channel preamp outputs (4-volt front, rear, and subwoofer)
    I usually purchase stereo's from local shops, but this time I went and got it from Crutchfield because they include everything you need and basic instructions ( with the exception of the steering wheel control cable, that is extra).
    http://www.crutchfield.com/p_113KDCX...6.html?tp=5684
    2000 Silverado 1500 Ext Cab, 2WD Vortec 5.3
    | K/N Cold Air Intake | Monroe Sensa-Trac front shocks | Monroe Sensa-Trac load adjusting rear shocks | Built in Canada | OEM replacement Headlight casings |OEM replacement Tail light casings | Kenwood Excelon Head Unit | Focal Speakers | Dash Cam | 265/70R16 Michelin LTX M/S2 | Rebuilt Transmission |Bosch Platinum 4 plugs | 2nd replacement windshield | G80 | Silverstar Ultras | Dual Yellow Tops | Black Lights | Fog Machine | 1500W Power inverter | 400W AMP | BlueTooth 3.x for hands free dialing | HD Radio Tuner | Diablo InTune Tune :great:| 6000K HID Lowbeams | 6000K HID High beams|All interior lights are 6000k LED's|Blue LED's in my cluster pack|LED's in Third Brake Light |WeatherTech front digitally matched floor mats |"Big 3" Electrical Upgrade |
    Last Post: 05-27-2011, 10:30 PM
  2. 2005 colorado no 4 wd
    By hundojoe in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 02-23-2010, 04:45 PM
  3. 2005 colorado
    By buckcgs in forum Member Introductions
    Last Post: 10-19-2009, 02:02 PM
  4. Replies: 0
    Last Post: 08-12-2009, 03:40 AM
  5. 2005 Colorado Reg Cab ZQ8
    By Gregsyellorado in forum General Classifieds
    Last Post: 01-14-2008, 09:13 PM
