    Default ABS warning light
    My daughter has a 99 S-10 Blazer 4.3L 2WD. The ABS warning light has been coming on the dash especially when it get very cold out (less than 20 dgrees). The brakes are very weak and mussy. Pedal goes almost all the way to the floor like she has no brakes. If you get it up to 10-15 mph and stomp on the brakes a couple times they been coming back to normal, but not anymore. I've heard this is the wheel speed sensor gone bad? And yes, the brakes are in very good condition and nothing needs relacing like the pads, rotors, calipers,etc... Any suggestions? And how would you determine which side it is?
    you can try to bleed the system until you get clean fluid out of each corner. does the abs actually kick in when the condition happens? almost sounds like something is not letting the system build pressure when cold. should get the abs codes checked to see what is happening
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    murdog94's Avatar
    Quote Originally Posted by Z71_guy View Post
    X2 on getting the codes read since this will tell you more than throwing parts at it since a bad sensor wont cause weak brakes.
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. Low Fuel warning light
    By Rychehawk in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-19-2010, 02:18 PM
  2. Batery warning light and odometer light on - help
    By filmir in forum General Chevy & GM Tech Questions
    Last: 09-29-2009, 11:54 AM
  3. warning light?
    By capt sensible in forum Audio, Video & Gadget Tech
    Last: 07-12-2009, 09:47 PM
  4. Engine warning light
    By Hoyt06 in forum General Chevy & GM Tech Questions
    Last: 04-22-2009, 07:19 PM
  5. Abs Warning Light
    By ejamin73 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 08-21-2007, 08:06 AM
