    Default Tachometer and other gauges not accurate
    So I have a few bulbs burned out on my cluster and thought that I could replace them myself. I soon found out that the bulbs are soldered in and decided that I can live with it for now. However, I took the needles off to get to the bulbs, and thought I got the needles back to their original positions. The tach is now way off (highway speeds it sits a 0 RPM), the voltage looks to be registering too high, and the speedo seems to be accurate, but when the truck is not moving, it seems to rest at about 4 mph, and I don't remember it doing that before. Any suggestions on how I can "calibrate" my gauges without taking it to the dealership and getting violated? Not really a big deal, but mor annoying because everything was working perfectly and then I had to "fix" it and did the exact opposite!!
    2006 GMC Sierra 2500HD Duramax
    stephan's Avatar
    Far West, Oregon USA,
    I can't tell you how to fix your guages but I remember seeing a thread on here about "how to guages" & it told the proper steps to do, or not do for guage work. It may go through steps that you can do or undo in order to realign your guages.
    3" susp. lift kit "shadetree"
    I believe this is the thread you're referring to, stephan: http://www.gmtruckclub.com/forum/sho...=gauge+cluster
    good luck, hope this helps
    stephan's Avatar
    Quote Originally Posted by TELORVEHC View Post
    That's the one TELORVEHC. It has the procedure for turning the needles till they stop, popping the needles & then the proced for puting them back on. I think if the op starts where he's at now & follows the disassembly & reassembly his should be right. Thanks for finding that.
    And a big thumbs up to 99Heartbeat (Mike) for making that write up on how to fix them..
  1. tachometer
    By challutz in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-11-2012, 05:10 PM
  2. 2003 Savana 5.3 Vortec and tachometer
    By grepfruit in forum Chevy Express Forum (GMC Savana)
    Last Post: 01-10-2011, 10:24 PM
  3. Replies: 5
    Last Post: 01-03-2011, 12:05 PM
  4. Tachometer
    By Pinkerton in forum General Chevy & GM Tech Questions
    Last Post: 10-21-2010, 03:03 PM
  5. Tachometer wiring question
    By BluBurb89 in forum General Chevy & GM Tech Questions
    Last Post: 07-28-2010, 10:49 AM
