Results 1 to 2 of 2
    Former Member
    Dec 2010
    Palmer Lake, Colorado
    Default Oil Cooler Quick Disconnects Leaking
    I recently replaced the oil cooler lines (Dorman - China)but they did not come with new O-rings for the quick disconnect side. They are leaking at the quick disconnects now where they were not before.
    Are the original O-rings high temp O-rings? Do they make a new seal kit for these quick disconnects? Looks like a clear plastic ring and an O-ring.
    I am pretty sure I can't plug the holes to bypass the cooler cause oil has to go out of one fitting and back in the other. If I plugged the holes I would not get any oil flow
    --I think-
    Should I just get replacement fittings? Haven't been able to locate them locally just yet. Oreilly's doesn't carry them here.
    Thanks for the help
    There isn't anything real special about the o-rings. Not very high temp or excessive pressure. There is a kit available to re-gasket the filter adapter. AutoZone usually carries it on the "Help" section. It includes the o-rings. I need to do mine soon, I'll try to take notes a maybe a pic or two.
  1. Engine Oil Cooler Housing Leaking
    By bro_hof in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-03-2010, 09:58 AM
  2. Leaking Antifreeze
    By 913projectchevy in forum General Chevy & GM Tech Questions
    Last: 11-23-2009, 10:44 AM
  3. Radiator leaking
    By Kickerking817 in forum General Chevy & GM Tech Questions
    Last: 09-19-2009, 05:54 PM
  4. Cab Leaking
    By dutzowmo in forum General Chevy & GM Tech Questions
    Last: 01-20-2009, 03:18 PM
  5. Still Leaking!?!?!
    By 95CTburb19 in forum GM Powertrain
    Last: 01-31-2008, 06:33 PM
