    Default 2003 Suburban doesn't shift into overdrive when its cold
    I've got an 03 suburban Z71 with 164,000 miles on it. I live in upstate NY, so when it gets cold out....usually from october to april...the tranny doesn't want to shift into overdrive. it usually takes about 10 miles or so before its warmed up enough so it will shift. is this normal that it should take so long. it shifts into overdrive just fine the rest of the year..and it always shifts fine into the other gears no matter what the outside air temp
    I bought the truck in febuary a couple of years ago (I bought it just south of rome down by the thruway) and I don't remember it doing it that first winter, but I know it did it last winter so I had the tranny flushed, but it didn't help. It works fine all summer long, but when the temp starts dropping it starts acting up. It just takes a long time to shift, maybe as much as 5 miles...shiftys into every gear fine, just not overdrive when cold. Kind of seems to me that its weather/pressure related somehow.
    gas mileage is a couple MPG worse on this suburban compared to my 99 i had before this, i blame that on the Z71 package.
    I've got a penn warranty on it, and I wouildn't mind getting the tranny fixed under warranty if I had to.
    my 99 does something along the lines of what your burban is doing, except mine does shift it just takes longer for it to until ive driven for a little bit and everything is all warmed up
    Go-Recon "xtreme" amber scanning tail gate light strip, Cobra ultra2 CB radio W/ 4 foot firestix antennas, dual exhaust with 40 series single in dual out muffler, 305/65R17 Mickey Thomson Baja ATZ on 17 inch Mickey Thompson Side Biters, 3 inch body lift
    "when the going gets tough the tough get cyclic:fighting0019:"
    "use the force luke:fighting0040:"
    Oct 2006
    Sheldon, Iowa
    kenny i have a 2000, with 162000 on original trans i live in iowa mines does something similar. Being an ex-gm tech it is normal, it probably is in fourth gear what your seeing is the tourque converter not locking, and that deals with the trans not up to temp on cold days at below zero temps it can take 3 to 4 miles at 70 to hit full locked overdrive this is normal to warm up engine and trans faster any questions just ask.
    thanks for the input. I wanted to make sure that it wasn't something I should be taking care of. the fluid looks and smells fine, even tho it was probably a year ago that I had it flushed. I really don't abuse it until it warms up and shifts out of 4th, not generally anything over 55 mph, but I am a vol. firefighter, so there are times when I push it a little harder.
  1. Transmission Won't Shift into 3rd or Overdrive
    By Elbutcho in forum GM Powertrain
    Last Post: 11-01-2010, 09:09 AM
  2. Won't shift when cold out.
    By Reviction in forum GM Powertrain
    Last Post: 12-23-2009, 12:14 PM
  3. Replies: 1
    Last Post: 12-15-2009, 08:31 AM
  4. Won't go into gear, won't shift into overdrive
    By TravelingOnTheOutskirts in forum GM Powertrain
    Last Post: 09-24-2009, 05:57 AM
  5. Looking for answers - 97 Suburban towing and overdrive
    By BuckeyeBandit in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 07-17-2008, 12:39 PM
