    Default Another Spark Plug Question
    The original plugs in my 07 4.3L GMC engine are AC Delco 41-993's (double platnum). I seached the info here at the site and the consensus seems to be to stick with OEM iridium plugs. My question is would I be better off staying with the double platnum's or will I be better off with the iridiums. I hoping the iridiums will give somewhat better performance?
    Jr. Engineer
    Mar 2010
    Cochrane, AB
    I put in iridiums last spring. I noticed a better sound, better pickup/pep from a start and slightly better fuel economy. I have no firm numbers for you or anything but I did notice a couple more Miles per gallon. However, there were NGK plugs in before I changed them.
    SEAFOAM, I PUT THAT @#!$ IN EVERYTHING!
    2004 Silverado LS 5.3L Z71 Crew Cab
    260,000+ km
    Quote Originally Posted by goldie View Post
    You would want to go with the A/C Iridium Tip Plugs and the reason is.....Iridium Tip Spark Plugs are the latest evolution in High Performance Plugs. The natural properties of iridium, with a melting point of approximately 700 degrees Celsius higher than Platinum, help enable the plug to burn fuel more efficiently and to deliver better performance. As a result, the Iridium Plugs have a minimum service life of 100,000 miles (service life varies with individual driving conditions.
    Master Mechanic daddytech's Avatar
    Mar 2008
    Portland TN
    I started Using E3 plugs in my 99 tahoe over a year ago and Instantly noticed a HUGE difference in performance and mileage. I know this doesn't answer your question about the irridium vs. Platinum / double platinum but that's my success story. They (depending on the plugs you have / get) may cost about the same or a little more per plug but the noticable difference makes it worth it to me and i have only lost 1 plug in all that time when i flooded my engine out with my own stupidity trying to run 100% E85 through my system to save on escalating gas prices. worked great for a few days but that's another story. aside from my own foul ups i have managed to not lose a single plug in 2 years now running those in both my wife's 98 suburban or my 99 tahoe.
    Thanks for the info. It is a great help. I did try the E3 plugs and they worked great for about 26-27,000 mile then I started to get misfires with them. Sure wish the would have lasted!
    The Vortec Engine's.....Run and Preform Better when using A/C Delco Plugs.......In some cases staying with Factory OEM Parts is the way go and this is One of those Cases.
    Again, thanks, I guess I've learned the hard way about plugs. I'll stay with AC Delco's.
    I know this is a way late response to the post. But after some research I discovered that NGK makes AC Delcos plugs... And the Delco Iridium is comparable to NGK's standard Iridium, but NGK makes a Laser Iridium that is better plug. So anybody browsing replacement plugs, take that into consideration. I went with the NGK laser Iridium in my 04 Tahoe 5.3 and love it.
    LOL way late? ~2 years is a bit more than late. *Grin* Good info though!
    2006 Vortec Max 1500
    Performance:
    Other:
    -Spray-in Bed Liner
    Chevy engines LOOOOOVE NGKs
    especially if you upgraded the ignition. even a simple coil upgrade.
    NGKs, man. i no longer run anything else.
  1. Spark Plug install question on 5.3 L 2002 Tahoe
    By billsf100 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 10-16-2010, 05:19 AM
  2. Spark Plug Gap
    By RangerJ in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-20-2010, 06:38 AM
  3. Spark Plug?
    By Chevyman224 in forum Performance & Fuel
    Last: 11-05-2009, 06:15 PM
  4. What spark plug to use?
    By partsman in forum Chevy C/K Truck Forum
    Last: 03-09-2009, 12:58 AM
  5. Spark Plug ??
    By Blakjax98 in forum General Chevy & GM Tech Questions
    Last: 01-04-2009, 10:58 AM
