    Default Battery Dies About Every 2 Days...
    Something is causing the battery(s) in my truck to die if I let it sit for more than a day, I replaced the old battery but the new one is doing the same thing, the alternator was tested and is fine, the truck is a 1981 Chevrolet C-10 I6 4.1L, also I live in Utah so it's been 19 and below here recently, any help?
    1981 Chevrolet C10 Custom Deluxe
    90,311 Orig Miles
    4.1 I6
    Something's staying on. Check that all your lights go off when you close up the truck, including the glove box light (happened to me once). Do you have any accessories? ie stereo amp, cb, dash clock, etc.
    Check for something grounding out - make sure all your lights work, check the starter and alternator wires, the grounding strap from the block to the frame, (and the little one from the battery to the fender, sneaky bugger).
    You say 'battery(s)' - do you have two, or the old and new ones?
    Good luck,
    1999 Chevy K2500 Suburban 350
    I had the one which came with the truck when I bought it and that one died and wouldn't hold a charge, I purchased a brand new one ($85 : /) and it is having the same issue(s), I have no clue what it is...
    The guy at Autozone tested the Alternator and said it was fine, I'm lost... : / lol
    oh and this truck is bone stock, not even a CD Player it has the good old tape deck...lol
    Well, my friend, you have some searching to do to find that wiring issue. I just saw a post about a bad starter causing the battery drain issue. Has it been starting hard?
    IDK it seems to start ok when it has enough juice to turn over...
    stephan's Avatar
    Far West, Oregon USA,
    The easiest way to find the draw that's dragging your battery down is to disconnect the negative terminal, & hook a test light between the cable & the negative battery post. Make sure everything is turned off & start pulling fuses one at a time untill the light goes off. When you find which circuit it is, post back & we may be able to give you advice on what to do next if it's a consumer, or one that should go through the ignition switch.
    Make sure you unplug the dome light so it is not lit while the door is open as this will show as a draw on your test light. Also bridge your test light across battery positive & negative first to check your test light before you start just to make sure it's working.
    Quote Originally Posted by stephan View Post
    I'll give it a try and LYK, thanx for the help... :D
    Check your battery cables and the grounding points. If there is a lot of corrosion at the battery or starter it acts like the vehicle isnt getting enough juice, in other words it steals the power. But for how old your vehicle is I would just get new cables anyway. For a 30 year old truck and only 90K on the odometer that means it has had its time in the stable, and that moisture can have a wicking effect and get inside the unsulation of the wires and cause corrosion too.
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
  1. 97 Suburban Dies twice in 2 days and restarts immediately, need some help!!!
    By lexisdad1201 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-18-2011, 08:32 AM
  2. Battery dies After 12 hours of Sitting
    By weekend wrench in forum GM Electrical Tech
    Last: 12-12-2010, 08:00 PM
    Last: 11-28-2010, 07:46 AM
  4. '99 Silverado Battery drain after setting several days
    By oldmangoodwrench in forum Member Introductions
    Last: 01-05-2010, 06:46 PM
