    Default Broken V/C bolt repair...
    So my Viking nightmare continues.... I picked up a used engine for my Suburban, as I stripped it of accessories etc.... I found it had a v/c bolt broken off flush with the head. I drilled a nice hole straight thru and proceeded to break off an ez out in it, below the bolt. I wound up driving it all the way to the bottom of the hole trying to chip it out. Drilling against it didnt work. Finally I used a die grinder to create holes around it, I got the damn thing out. Now I am left with an ugly large goofy hole.... What are some ways to fix.
    can i drill and tap jb weld?
    thanks in advance for your help...
    1989 Chevy V1500 Suburban 4X4, long tube headers & xover pipe. w/1985 350 4bbl.
    2002 Silverado 1500 5.3L Ext. Cab
    2005 Wrangler Rubicon 4.0L
    1990 Miata
    stephan's Avatar
    Far West, Oregon USA,
    I would get a thread insert & put in it to resize it back to the stock bolt size & thread pitch. This will make it a much cleaner repair. Stay away from helicoils. They are more difficult to use.
    Congrats on getting the broken off easyout, out of there. When I read that you had broken it off in a blind hole I thought you were sunk.
    3" susp. lift kit "shadetree"
    Thanks for the reply, any others that can share their fixes?
    Dec 2010
    25 Mi. E. of Kingman, AZ.
    How about JB welding a 1/4-20(or other size) nutsert into your over sized hole, maybe that would work. Put a bolt with release agent in the threads to keep them clean. As for broken bolt removal I sometimes weld a nut to the bolt and the heat helps with removal. I also have a set of left handed drill bits that help in times like this. Never had much luck w/small ez outs.
    Good luck with your new motor.
  1. being broken in
    By kingpin in forum Member Introductions
    Last: 10-18-2010, 10:54 PM
  2. Broken exhaust bolt
    By egreg in forum General Chevy & GM Tech Questions
    Last: 10-09-2010, 11:02 AM
  3. 1997 Tahoe 10 bolt to 14 bolt swap
    By miaatch in forum Lifted & Offroad Suspension
    Last: 10-06-2010, 11:20 AM
  4. Broken leaf spring repair
    By ty052003 in forum Lifted & Offroad Suspension
    Last: 06-14-2009, 04:50 PM
  5. Broken bolt in the manifold
    By Sierra23 in forum GM Powertrain
    Last: 05-09-2009, 10:25 AM
