Results 1 to 2 of 2
    Default radiator seam leak?
    My 1998 k-1500 4.3, 229,000 miles just started to drip from a seam below the filler. I just put new water pump in 2 weeks ago. I turned the cap back to relieve some pressure & it stopped. Any suggestion's? will it be all-right? dosen't over-heat. should I put some radiator sealer in it? by backing off the pressure, will it hurt my Vortek? Been snow plowing big time this winter & want what's best for my work-horse, what can I use to quick fix til I have time to put new radiator in it, with out hurting my motor cooling system?
    murdog94's Avatar
    Sadly there is no quick fix,
    Sealer will just plug everything up including your heater core
    Low pressure especially with a plow will cause it to heat up more than your temp guage will show and loose pressure.
    IT actually takes less than an hour to change a radiator. And that is the best options especially since your tranny uses the radiator for some cooling and with a plow that is important as well. I live in northern MN and see people with this problem a bit, and there really is no "quick" fix.
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. gm leak tabs on 5.7 intake manifold leak
    By raceville in forum General Chevy & GM Tech Questions
    Last: 01-13-2011, 02:06 PM
  2. Radiator Connection Leak
    By F E Knucklebuster in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-12-2010, 08:54 PM
  3. Radiator in 94 GMC z71
    By msu6745 in forum General Chevy & GM Tech Questions
    Last: 07-29-2009, 07:51 AM
  4. 2000 Z71 Tahoe - Radiator Leak
    By Wardi in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 05-12-2009, 12:33 PM
  5. need radiator for 69 to 70 C10
    By ras in forum General Classifieds
    Last: 08-15-2007, 06:40 PM
