Results 1 to 10 of 19
    Default climate control LED
    sorry i had such a long delay guys. i finished this back in december but been real busy lately. Heres my climate control blue LED swap. all the soldering wasnt too bad i used flat topped LED's for a wider viewing angle but as you can see it aint perfect, im fine with the way it looks in person it aint too bad, but no red in the temperature section. if i have the time ill go in to see what i can do to pop a red LED in there. And on the far right i did throw in a 5th led under the top middle of the directional flow knob, the eventual plan would be to do the same to the other two knobs but until then im in no rush, but heres the pic just so yall can see the product
    Aug 2010
    Sarnia, Ont, Canada
    i did the same thing. yours looks good tho.
    heres mine
    I have white led's behind the climate sliders. the orange led's that were in the a/c an the other two buttons are now white.
    Ive been thinking about doing something like this myself. My passenger side climate control bulb went out and was wanting to fix it anyways so...where did you guys find your L.E.D.'s at?
    Thanks,
    Dan
    '08 Silverado LT Z71
    Cast Iron 5.3 VORTEC
    K&N Cold Air Intake
    4L60E Trans with G80 Locker Rearend
    Line-X Spray in Bed Liner
    Tint, Eyebrow, & Blacked Out Emblems
    Flowmaster Super 44 SIDO
    hey, nice job brad. that looks real good. that white almost looks blue actually, which is neat in my opinion.
    and one wheel wonder i ordered mine at superbrightleds.com they are really an awesome site to shop.
    Yup the site is pretty sweet not gonna lie....i believe ill be ordering a hand full of lights here soon. which did you guys go with 3mm? 5mm? I think Im gonna go with red for the cluster and temp controls. (i just installed power windows and the switches already have red lights in them) and If im thinking correctly the wider the viewing angle the better? up to about 120deg anyways.
    Dan
    K&N Cold Air Intake
    Aug 2010
    Sarnia, Ont, Canada
    onewheelwonder, i used 5mm in mine, 3mm will also work well. an yes the wider the view angle the better, for light distribution so you limit the dark spots in the faceplate when lit.
    Sr. Apprentice Bigmacnchez's Avatar
    Oct 2010
    Granbury Tx, Fort Worth Tx
    How did you get the knobs on the sliders off
    Quote Originally Posted by Brad_'06_Silverado View Post
    heres mine
    2005 Chevy Silverado 1500HD 6.0 BBK headers,Cold air intake, Flowmaster cat-back, Diablo Trinity tuner, 22" KMC Rockstar Cooper ATZ, Kenwood DNX-9980HD indash, 2 Kenwood XR-W10F under back seat, Kicker 11DX10001, Kenwood KAC-7205, Polk Audio DXi6500 6.5"Component Speaker System front and back, Smoked out lights, 12K Hid's HI/Lo. Code Alarm W/remote start.
    Jr. Engineer Jaele's Avatar
    Nov 2011
    Fairfield CA
    Nice i like the look.
    I know this is an old post but $130 for parts? Ouch LEDs and resistors should not cost you more then $10 for 100pieces of each.
    Also here are some nice LED for wide angles, I used these in my tow mirrors(amber in color though(
    http://www.ebay.com/itm/100-pcs-5mm-...item5d3e05dd20
    2011 Silverado 1500 Z71 4x4 Crew Cab
    LED Dome light
    LED Floor lights
    RC Leveling kit
    Tow Mirrors Custom LED running/signal lights
    BakFlip G2 Tonneau Cover
    With mine i got 6 LED bulbs and 2 very small plastic tubes and cut it to fit in tightly inside the ac controls one twards the top and one twards the bottom. I mounted 3 on each and ran the power from my radio. 2 years later its still holding up
    superbrightleds.com is what i used
    what size resistors did you guys use?
  1. climate control
    By jdiggs in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-30-2010, 04:27 PM
  2. Climate Control fan
    By metalchecker in forum General Chevy & GM Tech Questions
    Last Post: 05-05-2010, 12:19 PM
  3. 05' climate control
    By TroyT in forum General Chevy & GM Tech Questions
    Last Post: 04-20-2010, 10:56 AM
  4. Need new Climate control
    By twarner776 in forum General Chevy & GM Tech Questions
    Last Post: 02-10-2009, 08:58 AM
  5. Climate Control
    By punkdu in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 01-25-2009, 12:22 AM
