    Jan 2011
    Mabank, Texas, United States
    Default Disable/Bypass auto headlights, 07 2500HD classic
    I have an 07 2500HD and I am wanting to either disable or bypass the auto headlights.
    Did a search and found some posts elsewhere.... A couple posters said to try a 1-ohm resistor or a 2.2 resistor and just wanting to confirm if any of this works or if someone has a better way to do this?
    Thanks guys.
    07 2500HD 4wd crewcab
    Jan 2011
    OK well I decided to give it a whirl and for anyone elses thougts....a 1.5k ohm resistor does the trick. Pulled the radio out reached up and got the sensor which had already fell into the dash anyways....pulled the sensor of and inserted the resistor in. Just bent it into a U shape and leave about 1/4" or so sticking out of the ends after you fold it and tape it and you are set to go! Works like a charm!
    hey just curious...
    i finally went to radio shack to get a 1.5K, 1/2 watt resistor for this disable mod, and im about to put it in, but as far as longevity, has anyone had any problems? all im concerned about is overheating or something of the like? or if its even the right resistor LOL,
    thanks for any response
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  1. Disable DRL [Expired Topic]
    By jp0933 in forum Chevy Equinox Forum (GMC Terrain)
    Last Post: 07-03-2010, 03:15 PM
  2. Sierra 2500HD Classic Turn Signal
    By wooly in forum General Chevy & GM Tech Questions
    Last Post: 02-22-2010, 10:14 PM
  3. auto headlights wont shut off
    By gunny in forum General Chevy & GM Tech Questions
    Last Post: 05-25-2009, 10:57 AM
  4. Converting Auto to Manual? Classic Body
    By KidHauler in forum General Chevy & GM Tech Questions
    Last Post: 05-03-2009, 01:14 PM
  5. Auto Headlights don't come on in snow
    By rsmits in forum Audio, Video & Gadget Tech
    Last Post: 01-12-2009, 01:38 PM
