Results 11 to 16 of 16
    Jan 2011
    Coeur d'Alene, Idaho, United States
    I don't think I will include a toilet. I will mostly be at actual campgrounds, rest stops or out in the National Forest (which means over a hole lol). I live in North Idaho so there is no shortage of any of those options. I have a plan laid out that will allow for a two burner coleman stove as well as room for a 7 gallon water tank. plus under the seating platform there will be a good share of storage as well as room of a large ice chest. I thought about a small propane fridge but, man those things are expensive. I am also installing a second battery for lighting, fan etc. If anybody has a good plan on how to do the battery set up I would sure appreciate it as I am totally not good at the whole electrical side of thing.
    I have a deep cycle for a second battery, along with a Cole Hersee Smart Battery Isolator. Definitely consider some type of isolator to keep from draining your main battery. One that allows a deep cycle battery may also be better for your needs, such as running 12V accessories for camping. I haven't had any problems with mine. I mostly use it to run compressors and other accessories, as well as a backup to jumpstart my main battery if needed. It is pre-wired through a momentary switch to do so. If you decide to just run two batteries in parallel, I would make sure to get two new batteries from the same lot from a wholesale dealer (not Wal-mart). I think you'd be happier with the isolator though, even if it's more expensive.
    ---------- Post added at 02:48 PM ---------- Previous post was at 02:43 PM ----------
    Looking forward to seeing pics of your conversion along the way.
    -Sal
    Desert Brown Metallic
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Welcome!!! Sounds like a great project. I'm a big camping fan myself....keep us posted as to your progress.
    TIRES:
    BFG All Terrain KO 315/70/17
    WELCOME, cool idea...PICTURES IS WHAT WE NEED THO !!!!! lol
    Scott:glasses:
    Jan 2011
    Don't worry I will post pics as I go along. Still considering options on the second battery but the isolator seems to be the option that every body else uses.
    murdog94's Avatar
    Welcome aboard!
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. 4wd turning problems
    By ntbush83 in forum GM Powertrain
    Last: 12-09-2010, 02:06 AM
  2. Clunk while turning
    By CGdoc in forum Chevy Truck Tech Forum
    Last: 11-02-2009, 08:49 AM
  3. Groaning while turning
    By SungloHeritage in forum General Chevy & GM Tech Questions
    Last: 03-30-2009, 06:45 AM
  4. AFM turning on and off continuously
    By gregstruck in forum Performance & Fuel
    Last: 10-26-2008, 11:37 AM
  5. Turning 8ft bed to 6 ft bed
    By dustin144 in forum General Chevy & GM Tech Questions
    Last: 10-09-2008, 01:31 PM
