    Default 2005 Chevy Silverado stalling while driving or at idle....
    My 2005 Chevy Silverado keeps stalling when I am at an idle or driving down the road. I have replaced: fuel filter, fuel pump, cap & rotor, plugs & wires and crankshaft sensor. Please help what am I missing?
    Ok does it do it all the time? Is your check engine light on? What are the codes? Have you checked for vacuum leaks? Now what exactly is it doing? Just flat out dying? Are the RPM's bouncing? Need more info to help ya better.
    2000 GMC Sierra 1500 Z71
    Stock 5.3L
    High Flow Filter
    Dual Exhaust
    KC Driving Lights behind Grille
    2011 17" GMC takeoffs
    Nerf Bars
    Toolbox
    Quote Originally Posted by Dieselman View Post
    What Brand of Spark Plugs did you install??.....and have you had the Trucks Computer Scan for any Trouble Codes??......also your Truck being a 2005"....the Gas Engine's don't have a Cap....Rotor.....or a Fuel filter.
    I am sorry, I had someone else post this for me. It is a 2004 not 05. It doesn't do it all the time. My check engine light is on and only reading 2 evap codes. Have not yet checked for vacuum leaks. It is not just flat out dying it sputters then cuts out. The RPM's aren't bouncing. I used AC/Delco spark plugs. I do have cap/rotor and fuel filter in my truck.
    Checked the EGR valve?
    Having a Cap....Rotor....and Fuel Filter.......Then your Engine is a V-6,
    These are the Trouble Codes for....EVAP System DTC's:...P0440....P00441....P0442......P0443....P0 446....P0453.....P0455.....P0456
    Technical Description Evaporative Emission Control System Malfunction......This indicates that a part of the EVAP control system is no longer functioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, fuel lines, carbon canister, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
    It could mean one or more of the following has happened:
    • The gas cap is not installed or working properly
    • The purge solenoid has failed
    • The canister is plugged and not working properly
    Here are some things to try:
    • Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
    • Inspect the EVAP system for cuts/holes in tubes/hoses
    • Inspect for damaged or disconnected hoses around the Evap purge solenoid
    • Check and/or replace the sensor
    • Check and/or replace the purge valve
    • Have a professional use a smoke machine to detect leaks
  1. Low idle and stalling on 2003 Suburban 5.3 - IAC??
    By ElbowJoe in forum GM Powertrain
    Last Post: 02-01-2011, 11:16 AM
  2. '99 Suburban 7.4, low idle, hesitation, stalling
    By TexasChris in forum GM Powertrain
    Last Post: 12-18-2010, 09:09 PM
  3. 2003 Trailblazer stalling at idle when AC is on?????
    By CharlieP in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 10-14-2010, 09:27 AM
  4. 2004 Silverado running rough idle/stalling out
    By KuttingEdgeInteriors in forum General Chevy & GM Tech Questions
    Last Post: 02-23-2010, 09:58 PM
  5. error code H02S-11, truck stalling/losing power while driving
    By pulawman in forum General Chevy & GM Tech Questions
    Last Post: 03-30-2009, 08:49 AM
