Results 1 to 2 of 2
    Feb 2011
    San Diego CA
    Question AC not getting cold
    I just bought a 99 Suburban with 104,000 miles. The rear AC gets a little cool but the front does not get cold at all, the compressor kicks on and stays on, the gauge on the bottle of R-134A I bought reads just above 45psi and just into the alert range. I did not put any freon into the system since it read over full. Any ideas.
    Thanks
    stephan's Avatar
    Far West, Oregon USA,
    The guage is reading the low pressure side of the system, or you hooked it to the high side by accident & it is undercharged.. I don't know how much experience you have so please read cautions below.
    Do the following with out the freon can hooked to your system!!
    Start it up, turn on the AC & look at the sight window on the reciever drier. If you see bubbles, it needs a charge. You may need a mirror & flashlight to see the window.
    CAUTION
    Always wear safety goggles when working on AC because liquid freon will blind you if you get it in your eyes, & MAKE SURE you know the difference between the high side & the low side of the system, because accidently charging through the high side of the system will blow up the can!! If you have no AC experience, I would recommend that you take it to a shop to be charged if it needs it!!
    3" susp. lift kit "shadetree"
  1. No cold A/C
    By 80skeys in forum General Chevy & GM Tech Questions
    Last Post: 04-19-2010, 05:52 PM
  2. Cold air kit
    By Bluewater in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-11-2010, 08:49 AM
  3. cold air
    By mike41 in forum GM Powertrain
    Last Post: 07-16-2009, 11:08 PM
  4. cold air intake
    By rholl23 in forum General Chevy & GM Tech Questions
    Last Post: 05-18-2009, 10:47 AM
  5. cold air
    By Silverado82 in forum Performance & Fuel
    Last Post: 11-30-2008, 08:28 PM
