    Default My 93 Burban has developed a whistle, I think it coming from around the Throttle body
    My wife had a mechanic friend look at it and he said it was the aftermarket intake and that we should put the stocker on. I removed the intake completely and it still whistles with just the open TB. I'm new to GMs, as I have owned Dodges for the past 8 years.
    Is this a common issue? I was thinking maybe IAC valve (assuming it has one?). I played with all the vacuum lines going to the TB and none seemed to be loose or cracked.
    Not sure where to start.
    Noise does not go away even once the motor is warm, it is constant and does not seem to be effected by RPM.
    It only does it with a warm engine. When the engine is cold from sitting all night, it won't whistle until it warms up. It will whistle if it has only been sitting for an hour or so.
    Any thoughts?
    Nobody has a theory?
    stephan's Avatar
    Far West, Oregon USA,
    Does this have a spacer on it? I've seen a few posters complain about a whistle when they installed a spacer.
    ** If not that, then maybe just a plain old vacuum leak? Spray around the intake with some carb cleaner or any thing else that will burn. When you hit the leak, the RPM will pick up.
    3" susp. lift kit "shadetree"
    No spacer. I'll have to stop and get some more carb cleaner. I used the last of it when I rebuilt my snowblower carb before the last storm.
    I didn't see any cracked hoses, but I'll try this.
  1. Throttle Body
    By crane557 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-16-2010, 06:07 PM
  2. BBK Throttle Body
    By StevieBlues in forum Performance & Fuel
    Last: 04-16-2010, 09:06 PM
  3. Throttle Body
    By doublej in forum General Chevy & GM Tech Questions
    Last: 04-01-2009, 04:08 PM
  4. Throttle body
    By 97silverado430 in forum General Chevy & GM Tech Questions
    Last: 12-28-2008, 07:11 AM
  5. Throttle body
    By andrejj in forum Chevy Colorado Forum (GMC Canyon)
    Last: 09-25-2006, 03:20 PM
