    Default bosch plugs bad for 99 S-10 2.2L ???
    my truck had a miss. shop replaced fuel pump because fuel pressure was way low. it runs better now but they said that the bosch plugs in it are the reason it is still missing a little. they said that i should replace them with autolite plugs or something like them. also said that the bosch plugs do not work well in an older vehicle with some miles on it. have about 150K on it. is there any truth to this or are they pulling my leg?? anyone else ever heard of this??
    Alot of people including myself on this site have found that the factory A/C Delco's work best in GM's.
    x2....On what Silveradotrailblazer has Mentioned on Staying with A/C Delco Plugs......the G.M. Engines Run and Perform Better went A/C Delco Plugs are being Install....Also In Some Cases staying with Factory/OEM Parts is the way to Go.....and this is One of those Cases.
    stephan's Avatar
    Far West, Oregon USA,
    X4, but it's AC Delcos you should use, (not Autolites, those would be the Ford plugs) I've never had a problem running off brand (Champions) but my truck is older than yours, & there have been numerous posters on here who've had nothing but problems with running other plugs in their Chevys/GMs'. Usually engine misses but occasionally hard starting etc. They swap the plugs out for a set of AC Delcos & the problems are fixed. It has happend too often to just be a coincidence.
    3" susp. lift kit "shadetree"
    X5...aswell as the OEM wires..or HUGE custom MSD's
    Scott:glasses:
    Bosch plugs are bad for all GM engines, especially the "special" ones like the +2 and +4. AC Delco is the only way to fly, NGK are also acceptable in a pinch.
  1. Bosch OXYGEN SENSOR chevrolet SILVERADO 3500 part 2001
    Last: 09-28-2010, 02:00 PM
  2. Bosch OXYGEN SENSOR chevrolet SILVERADO 2500 part 2000
    Last: 12-11-2009, 05:12 AM
  3. Bosch OXYGEN SENSOR chevrolet SILVERADO 3500 01 part
    Last: 11-09-2009, 10:30 PM
  4. Bosch Changes Direction on Brake Operations - Ward's Auto (subscription)
    By ChevyFan in forum Chevy Traverse Forum (GMC Acadia, Buick Enclave)
    Last: 07-31-2009, 01:40 PM
  5. Chamion "Truck Plugs" Spark PLugs
    By 4x4_only in forum Performance & Fuel
    Last: 08-12-2008, 08:58 AM
