    Default Alternator trouble?
    So this morning my truck has started up and the volt gauge would stay half between 9 and 14 which is around 11.5 and eventually kicked back up to 14, but it just started doing this today and its taking longer and longer for it to kick back up... i have a 130 amp alternator on my engine, it usually runs around 15 volts at all times, someone said voltage regulator? if not im going to have it tested tomorrow.. Thanks in advance
    2000 Chevy Silverado 2500 4x4
    6.0L v8:great: 4L80E
    2.5 in Daystar leveling keys
    285/75/16s BFG ATs on HD wheels
    Cab lights and tool box
    I would get your alternator checked first. when my alternator went out it did the same thing and it really sucks we it croaks and your miles away from anything and your truck quits. Been there, done that!
    If you can take it in and have it checked when your alternator is cold and hasn't been run for awhile. I took mine in while still in my truck and it showed good, bu died while I was driving to Idaho and the truck died out on the road.
    Ford has a better idea! Drive a GM!
    07 GMC Sierra Classic
    07 Honda Accord EX-L
    68 Camaro (blown)
    2011 Ford F550 V10
    I don't own this truck, I just drive it!
    stephan's Avatar
    Far West, Oregon USA,
    It could be the alternator/regulator, but it sounds like it could also be a loose ground, or batt/alt charging wire. Check all your alt connections, chassis ground, body grounds & batt cables. This is all easy & it's free compared to taking a shot at the alternator.
    3" susp. lift kit "shadetree"
    Start with a digital volt meter checking voltage at the battery. I wouldn't place much stock in the dash gauge, they are pretty numb. In addition, those trucks are notorious for stepper motor problems.
    checked the battery with a voltmeter, were exact same readings as dash, so i checked all wiring connectinons, they were good, so i ended up taking the alternator to advance to be checked and it was bad, was producing only 10 v so i bought a new one, all is good now thanks for all the tips to check first everyone i appreciate it.
  1. Bad Alternator?
    By jbaniaga in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 12-20-2010, 10:04 AM
  2. Could this be the alternator?
    By EdPDX in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-30-2010, 03:29 PM
  3. Alternator bad?
    By jdusmc214 in forum General Chevy & GM Tech Questions
    Last: 11-14-2010, 07:31 PM
  4. Alternator
    By Padre in forum GM Electrical Tech
    Last: 11-30-2009, 10:31 PM
  5. alternator
    By spooky in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-30-2007, 03:37 PM
