    Default Distribution block questions
    I was looking under the hood the other day, and it was looking like a rat's nest with all of the wires I have running off the battery to power my offroad lights and other accessories. So, being the neat freak that I am lol, I came across this distribution block to clean up the wiring----->http://www.knukonceptz.com/productDe...prodID=BC-3448 y'all think this will work if I run a single 4 ga. wire off the battery, then run the other accessories off the outputs, even though 2 of them are smaller than 8 ga. ? Also, I think 80 amp fuses will be enough for my other add-ons?
    Yea it'll work, I use two like it that use spade fuses to power all the electricals in my rockcrawler Toyota.
    Search around the Marine websites and they have some very nice water proof ones available at decent prices.
    Ok thanks for the clarification. Just wanted to be sure It would fulfill my needs before I went ahead and bought the distribution block.
    Well what is the Amp draw of the lights? And everything else? Say each light runs 30 amps, If you use 2 lights per fuse opening then a 60 amp fuse should be used. Now the wire run off of the batt should also have a fuse within 12 in's of the Batt.. On the block if you have 2 60 amp fuse's then you will need a 120 by the Batt..
    the lights are running less than 30 amps each I know that. And I already have a 120 amp fuse & holder ready to go, as I will be using that for when I install my sub.
    Just don't go over 10% of your total amp draw at the Batt.. You want that fuse to blow if something goes wrong. So if the amp you are going to use pulls 40 Amps and the lights only pull about 10 amps then a 50-65 Amp fuse at the Batt is all you want to use..
    The lights are essentially a pair of DDM 55w HIDs, according to DDM's website, they pull 6 amps at startup and 3.4 amps once they're warmed up. I have the 120 amp fuse that came with my wiring kit, which is why I was going to use that at the battery.
    Last: 11-23-2010, 09:54 PM
  2. New guy on the block
    By Megalomegalodon in forum Member Introductions
    Last: 09-14-2010, 01:44 AM
  3. header questions? and other exhaust intake and tune questions?
    By elkosp16 in forum Performance & Fuel
    Last: 07-19-2010, 04:56 AM
  4. First time towing questions.. Tire psi/Air-bag questions
    By beforeiforget761 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-16-2010, 07:39 PM
  5. GM Statement Regarding UAW Work Stoppage Impact on Parts Distribution
    Last: 09-25-2007, 05:25 PM
