    Apr 2008
    Louisiana
    Default 96 Silverado Need Engine Mount Removal Help on the 4.3L
    I own an 01 Silverado with the 5.3 L and am looking at getting a 96 Silverado (C1500) with the 4.3L. The engine mounts need changing according to the owner. I do not have the Haynes manual for the 96 Silverado and need assistance on the steps needed to change the mounts.
    The owner stated that he thought I could lift the engine, detach the coil springs, and remove the mounts.
    Anybody have the steps on changing the mounts?
    Thanks,
    Jeff
    2001 Chevy Silverado LS Extended Cab
    stephan's Avatar
    Far West, Oregon USA,
    This may sound a little bit simplified, but I would go buy your mounts first so you can see exactly how they work & how they will go in. Once you look at them you will see it's not as difficult job as you may be thinking. Yes you will need to lift the engine, & this is better done fron the top with a cherry picker or an "A" frame. Jacking them up from the bottom is kind of marginal because the only lifting points are the oil pan or under the harmonic balancer & these are easily damaged.
    3" susp. lift kit "shadetree"
    Apr 2008
    Louisiana
    I haven't bought the truck yet and just checking on how difficult a job it will be to change the motor mounts.
  1. radiator removal on a 2000 Chevy Tahoe with5.7 liter engine and 225,000 miles on it
    By chief771 in forum General Chevy & GM Tech Questions
    Last Post: 01-11-2011, 03:37 PM
  2. cb mount on 03 silverado
    By turner in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-30-2010, 02:05 PM
  3. Replies: 5
    Last Post: 10-05-2010, 01:52 PM
  4. gmc truck engine mount
    By darknox in forum GM Powertrain
    Last Post: 01-18-2010, 10:29 AM
  5. engine mount removal???
    By olblue91 in forum GM Powertrain
    Last Post: 08-25-2009, 09:09 PM
