    Default camber/caster adjustment bolt replacement on 85 sierra
    has anyone done these before? i need to replace the two bolts that pinch the shims between the frame and upper control arm. mine have loosened up on me twice and this time i cant tighten them anymore with out feeling like they are stripping. can definitely hear a clunk coming from that corner so i know they are loose. any help would be great.
    stephan's Avatar
    Far West, Oregon USA,
    Yes, they are pretty easy, just do one at a time & retain the shims in the proper place so your alignment doesn't change.
    3" susp. lift kit "shadetree"
    can you give me a little better detail on how to do them? im going to have to get new shims, i know iv lost some. i can do the alignment myself so thats no biggy.
    stephan's Avatar
    Can't think of much more to tell you. It's pretty simple. I would replace the loose one first so the tight one will hold the bar from moving. If you're not buying the GM bolts, then be sure & buy grade 8 hardened bolts so they don't strip again. Also if not buying the GM bolts, then make sure you get them long enough, because I've seen as much as 5/8" worth of shims in there to give them enough positive camber. Measure the total amount of shims you have left, & take a guess at how many fell out & buy extras for them.
    i looked under today and i actually have studs. wtf?
    stephan's Avatar
    lol, that makes it a little more difficult but still doable. If you can't get a good swing with the hammer to drive them out, try a long drift, or a steel rod. Do they use salt on the roads in Maine? If there's a lot of rust, spray them with some WD-40 for a couple days & it might go easier.
  1. 1997 Tahoe 10 bolt to 14 bolt swap
    By miaatch in forum Lifted & Offroad Suspension
    Last Post: 10-06-2010, 11:20 AM
  2. 93 ck1500 4x4 front camber adjustment.
    By trucker69 in forum Lifted & Offroad Suspension
    Last Post: 09-07-2010, 09:49 PM
  3. 98 Sierra speaker replacement
    By 98sierra in forum Audio, Video & Gadget Tech
    Last Post: 10-06-2009, 07:55 PM
  4. 2004 Sierra Front hub replacement
    By KD9RG in forum Lifted & Offroad Suspension
    Last Post: 04-30-2009, 12:09 AM
  5. help with bolt spacement of wheel gmc sierra
    By Chevy1997 in forum Member Introductions
    Last Post: 07-20-2007, 05:41 PM
