    Default 1993 transmission screwed
    ok i have a 1993 chevy silverado and my machanic just told me that my transmission is completely messed up, now i have always wanted a 5-speed vehicle and it just clicked in my head that now that i need a transmission that maybe i could change my truck. so what im wanting to know is if its even possible and exactly how difficult would it be to make the change, any information would be much helpfull, thanks to all who help.
    stephan's Avatar
    Far West, Oregon USA,
    Hey 5 speeds are nice, so do it if you've always wanted one. I'm assuming you have an automatic now, so you'll need to hang a new pedal cluster, you'll need a bellhousing , a flywheel & a clutch assy in addition to a new slip yoke for your drive shaft & you'll most likely need the drive shaft length changed. You might also need to change the mounting points for the trans mount crossmember. The easy way to do this would be to shop around at a salvage yard & try & find a donor truck with the trans you want & use it for all your other parts too, & be sure & get the drive shaft out of it too cuz it will be the right length & will have the right slip joint on it.
    3" susp. lift kit "shadetree"
    x2 on parts from the salvage yard. I've done a couple of these and that's by far easiest way to get the right parts.
  1. 1993 K3500 Silverado transmission rebuild question(s)
    By Geoffr in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-09-2010, 02:20 PM
  2. Now i am screwed
    By DAREDEVIL in forum General Chevy & GM Tech Questions
    Last Post: 02-04-2010, 09:10 PM
  3. 1993 GMC Transmission not shifting properly
    By Crispy3M in forum GM Powertrain
    Last Post: 06-25-2009, 11:10 AM
  4. Just got screwed!!!!!!!!!!!!!
    By vncj96 in forum The Coffee Shop ~ Chit Chat
    Last Post: 05-29-2009, 02:12 PM
  5. 1993 k1500 transmission swap
    Last Post: 05-23-2009, 11:58 PM
