Results 1 to 2 of 2
    Default Calibrating Edelbrock 1406 from scratch
    I recently ran into a problem my truck a 1969 C10 started blowing oil. Answer replace head gaskets. Once that was done I fired up the truck to adjust rocker arms and timing. A new problem showed my oil was full of gas. Since I have an electric fuel pump the answer was rebuild the carb. This turned into one hell of a project. The carb was so nasty I did a 100% tare down. I played hell getting all the linkage together correctly something even Edelbrock tech support couldn't help with. Now the next question is how to set up the mixture adjustments for first time startup. Any Help out there?
    stephan's Avatar
    Far West, Oregon USA,
    I'd set them both equal amounts 1 1/2 to 2 turns out each. When you screw them in to seat them & start your turns out, do not seat them too tightly or you'll ring the screws. Just lightly seated will do the job. After you warm it up (hot operating temp) & check all adjustments, ign timing etc, adjust the screws for the highest idle while alternately setting the idle speed screw back down. The air fuel mixture screws should each be kept the same amount of turns in or so your engine runs evenly side to side, & smoothly, especially if you have a 180 degree manifold.
    * and welcome to the club. Fill out a new member introduction so everyone knows you're here
    3" susp. lift kit "shadetree"
  1. someone scratch my truck
    By brownpridex111 in forum The Coffee Shop ~ Chit Chat
    Last Post: 09-25-2009, 01:18 AM
  2. Carburetor adapter for a Edelbrock 1406(Performer)
    By David8790 in forum General Chevy & GM Tech Questions
    Last Post: 09-15-2009, 04:12 PM
  3. Patch a small dime size paint chip/scratch 09 Silverado
    By mayers2007 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 09-14-2009, 09:14 PM
  4. scratch removal
    By Alexschiltz in forum Chevy Truck Accessories
    Last Post: 08-10-2009, 08:13 AM
  5. First Accident or scratch?
    By CkVin in forum The Coffee Shop ~ Chit Chat
    Last Post: 04-20-2005, 10:09 AM
