    Default Transmission interchange - mechanical speedometer w/ speed sensor
    The trans in my old van has seen better days. I'm gonna have to pull it to fix a leaky main seal or cam plug on the new engine, So I wanted to see if anyone knew of a good year/model transmission I could use.
    My main requirement is that I have a mechanical speedometer. I wouldn't mind going to an OD trans that's computer controlled, but it would have to have an electric speed sensor with a mechanical speedo cable. I'm thinking it would need to be somewhere in the 88-92 year range. Anyone know if any 2wd trucks/vans in that range had a mechanical speedo?
    Wait, so it needs both a speed sensor AND a mechanical speedo output? I don't think those exist. If you just need the mechanical speedo, I think you can swap the tailshaft with one from a mechanical speedo 700R4 and be fine. If you need both, I think you'd still need the mechanical speedo tailshaft and one of those speed sensors that ties inline with the speedo cable like they use for the cruise control setups. From 88ish on they only had speed sensors; not even Suburbans still used mechanical speedo cables.
    Christopher
    OK Thanks. I only questioned it as I wasn't sure if GM had put the sensor on vehicles with mech speedo. My 89 mustang had a cable driven speedo with an electronic speed sensor as well, where the cable went into the trans. So Ford did both, wasn't sure if GM did.
    I don't necessarily need the speed sensor, but I *think* it's required if you do trans control with the computer.
    With the 700R4/4L60E, the speed sensor and mechanical speedos pulled off the same spot, a couple inches into the tailshaft. So, you'd actually need the tailshaft and the gear off the shaft that drives the speedo cable.
    Christopher
    OK thanks for the info.
  1. transmission interchange info?
    By senorbob999 in forum General Chevy & GM Tech Questions
    Last Post: 10-09-2010, 02:22 PM
  2. ABS warning light/ speedometer/ transmission Issue?
    By Doug357 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-20-2010, 11:21 PM
  3. Speed sensor
    By Jim Nolan in forum GM Powertrain
    Last Post: 02-26-2008, 11:07 AM
  4. Transmission Interchange
    By Dahoopd in forum GM Powertrain
    Last Post: 10-12-2007, 09:02 PM
