Results 1 to 9 of 9
    Master Mechanic
    Apr 2009
    Owens Cross Roads, Alabama
    Default 2002 avalanch stuck in 4 hi
    A friend of mine back home is having trouble with her truck.its an 02 Avalanche with push button 4wd. Im still deployed so Im tryin to help her from here so she wont be lied to at a shop or anything.
    The truck is stuck in 4hi. she has tried to get it into 2wd and 4lo but nothing... She said she can hear somthing under the truck (Im assuming the transfer case) attempting to disengage the 4wd but it never actually does it..so Ive ruled out the possibility of bad switches..any other ideas?
    thanks
    -Dylan
    2004 Silverado 4x4
    4.8L
    1986 K5 Blazer
    8" Superlift w/39.5 super swampers
    1992 GMC Jimmy "Blue Bomber"
    4.3L Vortec
    Master Mechanic
    Apr 2009
    anybody????????????
    Tell her to check the relays or fuse under the hood. Or it could be something bigger under the truck..
    Does she have the "Service 4WD" message? Most likely the encoder/motor. Push button 4x4 uses a motor to shift the transfer case in place of a shift lever. It also has a position sensor to tell it where it is, 2hi, 4hi or 4lo, Sometimes it's just the sensor, which can be replaced by itself or it's the motor itself. If it's the motor I believe it comes with the sensor as a whole assembly. She's probably going to have the codes read to determine if it's the motor or just the sensor. I just replaced mine a couple of months ago, mine was just the sensor but I had them replace the whole thing.
    Adam
    Master Mechanic
    Apr 2009
    as far as i know shes not getting the famous "Service 4wd" message.but I'll ask her.thanks for the help guys.I'll bring these up to her and see if we can get this thing figured out.It'd be alot easier if i could see it myself haha
    Adam, that sounds like the most likely problem to me..from the way shes describing it to me, it seems like the motor is attempting to shift out of 4hi but just cant pull it off..would you happen to know what the technical term for the motor is?
    I'm pretty sure G.M. refers to it as the transfer case encoder motor.
    Quote Originally Posted by adampaul1964 View Post
    thats what they called it when they replaced mine. my problem was a little different from what was described, but similar in the 4wd acting up and no service light.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Master Mechanic
    Apr 2009
    alright thanks guys. shes gonna go ahead and send it to the shop. but like i said i just didnt want anybody trying to take advantage of her and want to replace everything in the world to charge her some outrageous amount
  1. Location of fuse box - 2003 Avalanch?
    By tontruck2 in forum General Chevy & GM Tech Questions
    Last: 06-11-2010, 11:37 PM
  2. stuck in 3rd
    By gecko094pat in forum General Chevy & GM Tech Questions
    Last: 01-11-2010, 10:54 AM
  3. Avalanch to silverado tailgate swap?
    By Tiny1987 in forum General Chevy & GM Tech Questions
    Last: 06-30-2009, 04:25 PM
  4. 2002 Chevy Trailblazer Stuck in park
    By Flywhip in forum GM Powertrain
    Last: 11-12-2008, 10:14 PM
  5. Got stuck in the mud......
    By DirtDog in forum Photo & Video Gallery
    Last: 02-17-2008, 04:06 PM
